I just picked up photo lights made by Mayfair Manyfacturing at an antique store. The model is flexmaster, and has four movie flood bulbs on flexible stalks that can be controlled by a push-button panel. Settings are dim, half, and bright, and off. Can be mounted to a stand as well. Appears to be made in the 60's, new in original box. Any good?
I have a similar set that I have used successfully, but the bulbs burn pretty hot and get uncomfortable after a while. I prefer a couple of plain reflectors with 5000� CFL bulbs. You have to special order these bulbs, so you might try the more common 6500� CFL's and see if they work for you. If not, they're great in the shop.
I had exactly the same first thoughts about the bulbs and potential problems with these older lights: 1. Color temperature and 2. that the bulbs likely create a lot of heat. These movie units were not made for close-ups, and the films being used then were balanced for the redder lights.
If you used them as sources for reflected/bounced light as a diffused source, it might be OK as far as heat is concerned, but color temperature is still an issue.
Bulb replacement might also be an issue in terms of availability and cost. One bulb may cost more than what you paid for the whole rig....
Ditto what Rob said. They do work and they are 3200K so the Tungsten setting on your camera would work fine. However on shiny objects they either produce 4 hot spots or one long very bright hot spot. I think finding replacement lamps might be interesting at best. They are also fragile and easily broken. I think I have 2 of them in my collection at work.
It's much easier to just use Quartz Halogen work lights. The bulbs last forever. You only have one small hotspot to deal with and you can put a diffuser in a foot or so in front of it if you want a larger soft light.
