Hello all of you Jet 1642 owners.
ted evans
Last summer I purchased a Jet 1642 EVS 2HP lathe, which I have not had a lot of time to turn on. However, there seems to be a problem developing with the lathe. Some weeks back, I noticed an intermittent clacking noise coming from the motor at speeds below about 800 rpm. This problem has gradually worsened until the clatter is now present up to about 1900 rpm or so. Beyond that speed, it is quite and runs very smooth; below that speed, it becomes noisy and has vibration.
Adjusting the belt from tight to loose to no belt, makes no difference. The motor shaft appears to run eccentric, although I have not put a gauge on it. Does this sound like a bad bearing or some other problem? Have any of you experienced a similar problem with your 1642?
Thanks for your comments.
Ted
