Owners poll-Nova 16/24-44
Bart
Could the owners of the Nova 16/24-44 lathe please put up a review of their lathe here. Thank you.
Bart
Older Nova 3000- ALL GOOD!
steve antonucci
And the upgrades they made are for the same cost. Great value. 8 years and going strong on mine. Thousands of hours on it...
S
Re: Owners poll-Nova 16/24-44
Steve Kubien
I can't see how you can do better for the money. If you want to turn max-diameter bowls (very close to 16"), I would recommend a larger lathe and this has to do with the design of the headstock casting. It will happily work anything under 14", those if it is un-balanced, you will have to drop the speed.
It is a fine spindle lathe for things like peppermills, pens, candlesticks.
For this size of lathe, 1.5hp is plenty of power. You can stall it but you can stall any lathe if you want to.
The banjo and tailstock lock down nice and firm.
The toolrest is a piece of crap. Figure to replace it immediately. Oh, it is terrible.
Speed changes are easy, especially if you remove the red cover thingie. Sure you end up getting some chips in there but the advantages FAR outweigh the cons.
Having said all of this, I am currently looking/hoping to upgrade because I want to be able to handle larger, out-off-balance pieces. I'd also like more length, which if it were not for point A, I would happily achieve via an extension. When I do upgrade, I may very well keep my 1624 as a solid performing back-up or travelling lathe.
Ed Wujciak
I've had mine for a little over 3 years and like it a lot. It's a HUGE step up from my Shopsmith 10ER from 1953....
I use it with the standard factory legs plus I needed to raise the whole shebang another 5" or so to get it to a CWH. For these reasons, it's not too good with unbalanced blanks - ya gotta go sloow till it's sorta round. Also I've never been happy with the precision with which it indexes back to spindle mode. It's really hard to drill a truly centered hole with the amount of slop in the headstock. I compensate by trying to avoid situations where that kind of precision is critical and be extra-careful when I can't avoid them.
Beyond those gripes, I love the lathe. It's compact but long enough for my needs. I've never hated the toolrest and use it a lot, but I also have a selection of other rests for "other" situations. I'd be reluctant to remove the red "thingie" because I fear a sleeve or finger finding a way in....
All in all, a great value that does what I need. When I strike it rich, I'll upgrade. Till then, I'm satisfied.
