FT American Fountain Pen
Marc Phillips
Here is a fountain pen I just did .... I will post a pic of the opposite side... hard to believe these 2 pics are of the same pen since the opposite sides are so totally different.
I am still working on getting these decals on the pens .... for some unknown (to me) reason I get these white opaque areas sometimes... and haven't been able to pin it down as to what causes it.
Thanks for looking....
Re: FT American Fountain Pen
FT American Fountain Pen - other side
Marc Phillips
Ric Taylor
Ric Taylor
Marc,
If those are water slide decals, the problem is caused by air under the decal. To eliminate that problem, the decal has to be applied to a very smooth glossy surface, and then sealed under a top coat.
If they are not applied to a smooth glossy surface, then the result is many tiny microscopic bits of air trapped underneath, resulting in the problem that you see on the pen.
Look at model airplane forums for many discussions of how to make the film of decals invisible on the final product.
Ric
