Vacuum Pump
Jeff Rich
Has anyone used the HF 2.5 CFM Vacuum Pump for a Vacuum Chuck?
They have a special on this pump and I might get one to build said chuck.
Thanks!
Vacuum Pump
Jeff Rich
Thanks!
Re: Vacuum Pump
I have no idea about the quality of the HF pump or how much vacuum it will pull. (Except HF is not usually mentioned in the same breath with reliability and quality, more like it was cheap so I bought it anyway.) I can tell you that I have a 1.1cfm Gast pump and it works for vacuum chucking on the lathe. It might be better if it had more CFM. I have to be really careful about leaks. You might want to look into using a reservoir in your system to give you a few seconds to get the piece off the lathe if the pump quits. Also, In my experience you don't need maximum vacuum. 20+ inches might be just as useful as 28".
Check out some of the salvage places and see if your area has a contractor that restores Dentists offices. Sometime you can pick up an excellent pump cheap. Also check out he Joe Woodworker site. I have been reading there. I am ramping up to a vacuum press.
Re: Vacuum Pump
Doug Wolf
I built a vacuum system using a GAST 522 pump (rotating carbon vanes) and @ 5,000 feet can pull 22" of Hg. My friend wanted a vac system but couldn't find a GAST pump so he bought the 2.5 CFM Harbor pump. His also pulls 22" of Hg. However we both run with a bypass valve partly open to prevent the bottom of the turning from colapsing, usually ending up at about 10" of Hg. He notices a slight amount of oil coming out of the discharge of his pump when running with the bypass valve open. He's happy with his system and now that it's on sale it's even a better deal.
Re: Vacuum Pump
Ralph
I also use one, been using it for at least a year. Several other members of the local club also use this model. It has appeared to work solid for all of us, we all have gone to the local NAPA/AutoMart/etc store and bought extra oil as it does consume oil. One of the locals added an oil trap to his outlet side. I set mine on a large old rag.
Re: Vacuum Pump
Bill Howatt
Oil trap is a good idea. Oil fumes are supposedly quite nasty things to inhale.
Bill
Re: Surplus Supply
Steve Criscenzo
It is hard to beat the Gast at Surplus supply. Been using mine for five years without a hitch. Only potential problem is it runs on 220V.
Steve
Re: Surplus Supply
Doug Wolf
They have been out of stock for awhile, that why my friend bought the Harbor Freight pump.
Re: Vacuum Pump
Walter Ahlgrim
Take a look at this pump 4.2 cfm with gage and filter $175.00
http://www.stubbylatheusa.com/cgi-bin/index.py
This pump is brand new and quieter than most.
Walta
Re: Vacuum Pump
WoodSpinner
I've been using a compressor from an old fridge for a vacuum pump for about 3 years and havent had a problem with it yet.
