Re: Punky wood
Wally Dickerman in Arizona
Yep, that was my article. First, I agree with John Jordan...Life is too short to turn crappy wood...However, if the wood is something special then it might be worth spending some time to make turning it possible.
I had a number of blanks that were figured and spalted maple and had some punky spots. Just barely able to sucessfully rough them out. I decided to try the glue method. I bought a gallon of white glue, which isn't very expensive, and a small plastic tub. The mix was 50/50. White glue is nearly all water anyway. I soaked the roughouts one at a time for about 24 hours. (longer might be better..I haven't tried it). I had to put a rock on the piece because it wanted to float. You are soaking the piece in water so expect it to warp as it dries. Drying time was a couple of weeks. (The wood was dry before I soaked it.)
The results were from very good to not so good, depending on how punky the wood was, and how large the punky area was. I've done this procedure several times since with varying results.
Wally
