filling cracks?
filling cracks?
filling cracks?
nick
Where can I find info on filling cracks with black epoxy or something else?
Re: filling cracks?
Dick Hines
Re: filling cracks?
Dick Hines
How big are the cracks? Woodturners catalog has a black stone dust that can be mixed with thick CA and squeezed into the cracks if not to large.
Re: filling cracks?
Re: filling cracks?
Bill Howatt
As was mentioned, what works may well depend on the size of the crack. Coffee grounds and CA glue is a common solution.
For filling cracks with a very fine black material, I have used black milk paint poweder and CA or epoxy. The little bit of black toner that remains in a used laser printer cartridge also works well. When using epoxy you have to mix a fairly high percentage of powder in the mix or else the clear epoxy will be obvious.
I find the coffee ground solution (I dry the used grounds) to be a very useful one since it blends well with a lot of woods and doesn't look too synthetic especially if there is some bark inclusions in the piece.
If you aren't aware, CA is cyanoacrylate glue common known as Krazy Glue, Super Glue, etc.
Re: filling cracks?
Re: filling cracks?
Edward Bartimmo
Take a look at System 3 Epoxy website. They did a study on various types of additives, paint pigment, etc added to epoxy. It is fairly comprehansive based on colors, translucency, and color consistency. Good luck
Re: filling cracks?
Re: filling cracks?
arkie
I use coffee for small cracks. In addition to the grounds previously suggested, I keep a jar of the cheapest generic instant I can find. I want something I can crush to a fine powder with my fingers. I use this for very small cracks, then drizzle on a drop or two of thin CA. I prefer the brown of coffee to the black of laser toner.
I've never worked with wood so scarce that I felt obligated to pursue a large scale "design opportunity."
Re: filling cracks?
Re: filling cracks?
nick
Do you finish the wood first? Or do you put the glue on bare wood and then sand away the slop?
Re: filling cracks?
Re: filling cracks?
fgvanatta
You put sanding sealer or wax on the bare wood first to keep the glue overrun from staining the wood.
Frank
Re: filling cracks?
Re: filling cracks?
Bill Howatt
I usually do the filling in advance of any final cuts. The final cuts and sanding will remove any traces of the glue normally. You can certainly use a "protect the surface" method or both methods together.
Unless you are a real artist, the surface of your patch is going to need cutting to get a smooth surface and blend with the surrounding wood.
Bill
