Got a new tool (from an old tool)
Steven Antonucci
Steven Antonucci
I spent a few hours this past weekend with Jean Francois Escoulen, who is a tremendous turner and demonstrator, and remarkably funny man. He is known for his multi-center off axis work, but I suspect he could turn anything he wanted to turn.
While in the sessions, he focused on using as few tools as any turner I have ever seen. His weapon of choice? The bedan, which short of the Kelton bowl savers was about the most unused tool in my shop. He commented that a small relief at the underside "long point" made a huge difference,and then proved it by doing this:
The crowd was relatively small compared to some of the other sessions, which really allowed us to ask him some questions and understand what he was doing. I made some mental notes, and decided to regrind my "fat parting tool" to the way his was ground. I set off to see if I could cut with it.
Chalk one up for the French. By the first minute, I had pretty much worked out all of the motions. I had a scrap of red oak from a baluster, so I set out to make a trembeleur. Red oak is not a great material for this, but it was in reach.
Here is my effort with a bedan:
Standard pencil in the picture is for scale, I did not turn it. :)
When I get a minute or two to make some string steady rests, I will go for the real thing.
Steven
Re: Got a new tool (from an old tool)
Re: J F Escoulen's bedan is a "French"...
JamieDonaldson
....model that is 1/2" square, rather than the usual "English" bedan which is not square as JFE says with emphasis!
Jorge Casta�eda
Steve,
Could you expand in that
"a small relief at the underside "long point" made a huge difference"
Can you describe it or made a picture of it?
I did sit a 3 of his demos last october at the Ohio Valley Woodturners at the Higher Ground and was very impressed by the fact he only used 3 tools, the bedan (a square 1/2"), a skew and a detail gouge, this last one to hollow.
Unfortunately I was under heavy medication... got some pictures tho. He is incredibly productive and made 6 or more pieces each demo, anything from trembleurs to table legs.
Don Evans
Jorge:
If you have a bedan turn it so the bevel it UP. If you are right handed, take it in your left hand with the bevel up and pointing to the right, with right hand take a diamond hone a flat one like an EZE LAP. Lay the LAP against the bottom of the tool with diamonds touching the underside of it. Move the LAPs handle up so the diamonds only touch about 1/16th inch at the bottom of the point. You move the handle so you will cut only at about 2 degs for that 1/16th of an inch.
This will create the underside bevel.
The tool must be used with the large bevel up the small bevel just created will be down. The secret to the bedan is to move the tool rest up so that the bedan is laying on the wood and the rest and at that point it is horizontal.
If the point is on top of wood and point in middle of wood you move it back toward you slightly, raising the handle then makes it cut. Twisting it just like a spindle qouge allows cuts just like the gouge.
Basically you have half a skew but with different angle of cut.
Don
Don Evans
Thats interesting that he would say that. His bedan with his name on it is NOT square but rectangular, taller (with bevel up) than it is wide. The english bedan with bevel up is wider at the bottom than the top, made that way to keep it from being trapped on the sides.
I purchased one of his bedans from him which is 1/4" approximately and it is one of my favorite tools for detail work.
Don
Don Evans
Forgot to say above,
NEVER NEVER grind on a bedan, it only needs to be honed with diamond fine grit EZE LAP or similar one.
Two or three strokes on top bevel and botton one if you creat it is all needed.
I've had these tools for around 12 years and they have never touch a grinder. Is it sharp enough, I think so, I've pushed it with holly and maple to 1/16" spindles.
Here is one example if I did this right, thats african blackwood with tagua nut on top.
Don
Jorge Casta�eda
Don,
Thank you very much, that is a good explanation. I have an ancient bedan british style, I'll get it out and practice.
Yo do beautiful work,
Thanks for posting it.
Jorge
