Multi-Axis Idea For "Hakada" Doll
charlie belden
I picked up what I think is called a "Hakada" doll - cloth body with silk robes and wig. The head is chewed up - like a cat played with it - but the silk robe is fine.
So - I'm playing with ideas for turning a multi-axis piece on which to put the robe.
I've dabble in multi-axis turning, mainly just learning how things work and thanks to Barbara Dill's article, have a rudimentary understanding of what does what. Other than magic wands, candle holders or weed pots and a few three sided christmas ornaments, I couldn't come up with a use for multi-axis.
But in the back of my head Jennifer Shirley's figures have intrigued me. Take that idea, use mulit-centers - and a twist . . . And if you've seen Peter Rand's Kinetic Tryptich pieces on WOW that used multi-axis the artistic possibilities are also obvious.
This idea breaks down into turning different areas of the piece using different sets of centers - simple round for the base, 3 intersecting arcs - with a 90 degree twist, 2 interesting arcs with the earlier 90 degree twist and finally a tapered round neck and oval head on the same axis.
Off to SketchUP to play with the idea and here's the basics of it.
A little sanding to blend things ("little" probably meaning hours and hours of sanding) and maybe stop with a stand alone piece - or adorn it with the silk robe - and possibly "hair".
Perhaps a 90 degree twist will get reduced to a more subtle 15 to 30 degree twist, as if she's just beginning to turn her head and shoulders towards someone.
Possibilities? Or - just another Wild Hare Idea. C&C welcomed
