THE WOODRAT IS BACK!
Third Goblet from this Ash
Jeff Rich
Hello Everyone,
Here is the third goblet out of the ash I recently purchased.
I bought kiln dried stock because I wanted very little movement.
Otherwise, I would have used "found" wood.
I am doing some practicing with these smaller blanks before tackling the larger blanks.
The smaller blanks are 7.5"x3" The larger blanks are 9"x3"
My intentions are to send my friend a near matching set.
Comments are welcome
Re: Third Goblet from this Ash
Nice - I love goblets. They are a favorite of gift-getters.
You mentioned using kiln dried wood to minimize movement. Have you ever made goblets from green by roughing and air drying, as is common with bowls? I use that method for goblets and boxes. The dry pretty quickly and can be microwaved if in a hurry. (Green wood is basically free and I'm a cheapskate!)
adrien
John, are you turning green and THEN air drying or rough turning and then
finishing once it's dry?
charlie belden
You've got a nice shape and the details work. But it appears that you're sanding away any crispness to the details, perhaps because of the choice of wood and the potential problems turning dry wood - expecially tear out. Shadow lines can add interest to a piece - but if they're "washed out" because everything's been rounded by sanding . . .
You can keep most of the original turned crispness when sanding is necessary - IF you use the right sand paper and use it well.
Jeff Rich
Hi,
Thanks for the comments!
I have used green wood before and did the rough turning and let it dry.
They turned out pretty nice. I have to do bigger goblets the green wood way as there is not a lot of 5x5x10" kiln dried around.
Besides, green wood is more fun to turn.
The crispness is there with the details, however the macro focus on the camera is bugging out and I am trying to figure it out.
One of the few things I learned early on was over sanding can ruin a piece.
>turning and then finishing once it's dry?
If it is a box where the lid must fit or a goblet that I want to be sure to stay round, I rough-turn a little thick, let sit for a while to air dry (usually until I get to it, maybe months), then final turn. This is real important for lidded boxes but not so important for goblets unless the figure is all squirrely and/or the goblet is very thin. Besides fresh green wood I do the dense exotics this way since the wood is usually not totally dry inside even if it's been sitting for years. (Wood bought dipped in paraffin is often pretty wet inside) Fortunately since these are end-grain turnings they don't go much out of round as would a side-grain bowl, so the rough turning can be pretty close to the final size.
BTW, even when air dried and final-turned I don't usually try to fit the lid immediately. For the best fit, one of the box-making books (Raffan's?) recommends leaving the box at least overnight to let the turning-induced or -released stresses relax.
Re: I can determine from the barrel......
JamieDonaldson
...distortion in the image that you are using a wide angle focal length rather than the longer tele zoom FL, and that may be part of the focus problem. Back up the camera position and try the longer FL for both cropping and less distortion. Unfortunately not all cameras can close focus at longer FL, but it usually works better than the WA macro focusing range.
Jeff Rich
Thanks Jamie!
I have trouble with my little HP215 from time to time.
It is a fixed focus/zoom type of digital camera.
Lighting also affects picture quality, generally Cheri takes a lot of outside pictures and they turn out great....hmm, maybe I should do some outside pics.
I think its time to upgrade to a little better camera.
Maybe I will just have Cheri take the pics.
