Don at Central Illinois
John, I think I read in a thread that you made some Ellsworth type hollowing tools. I am thinking of trying some, but would like to see a photo of the tips and how you mounted them. Not just for John, but anyone that has that type the made. Also, where did you get the tool rod? Thanks in advance for any help.
Re: John Lucas
Re: John Lucas
don If I get home early enough tonight I'll take a few photos. I use the HSS cutters in my larger tools, 1/2" through 3/4". I have made a couple of 1/4 tools with the HSS silver soldered to the end. On those I cut and filed a Rabbit so the cutter had 2 surfaces to bond to. Then just soldered them in place with silver solder.
On the 1/2" bars I drill a 1/4" hole and then just glue the 3/16" cutters in the hole with medium CA. You may have to very slightly grind the corners of the cutter depending on how accurate your 1/4" hole is.
On the 5/8 and 3/4" bars I still drill a 1/4" hole but I drill and tap a hole to put a set screw in.
Re: John Lucas
Re: John Lucas
I saw a demo with Ellsworth last Saturday and I noticed that his top of his tips were at the centerline of the drill rod. Don't know if that makes a difference or if I can just drill a hole in the center of the rod and install the tip. That would make the top of the tip a litte above center of the drill rod, but don't know if that will make a difference or not. I guess that's why I want the photos.
Re: John Lucas
Re: John Lucas
fgvanatta
Here's a small set made from cut nails. The handle is from Boeing surplus. The black marks on the tools are depth indicators I have added when hollowing different pieces. When the marks get confusing I just clean them off with alcohol and start over.
Frank
Re: John Lucas
Steven Antonucci
Here is a sample
Steven Antonucci
Drilling on centerline for handheld tools is really not that necessary. David was making a batch of tools in his shop for Crafts Supplies, and he's got all kinds of jigs to make them repeatably, but I've always freehanded mine.
The most important things in the making of the Ellsworth style bars is getting the cutter level and securely attached. In addition, it also makes sense to match the size of the cutter to the size of the bar. I like to use 1/8" cutters on bars under a 3/8" thick because they take a smaller cut, so they vibrate less. On 1/2" bars or bigger, I can go up to 3/16" or even a 1/4" on a 3/4" bar. Bigger bars vibrate less, but also require a bigger hole to cut through.
On the 1/2" bar or bigger, I like to use a set screw. Put it on the underside (not the top) or it will pack with sawdust. You can also use CA clue or epoxy, or silver solder. It's up to you. My larger bars have two holes (one straight and one angled to keep the clutter down in my tool rack.
The steel comes from Home Depot. It does not cut, so any kind of bar will do. the cutters come from Enco.
Steve
Re: John Lucas
Re: Here is a sample
So you don't use O1 drill rod? Just cold roll steel for the bars?
Re: John Lucas
Steven Antonucci
Correct
Steven Antonucci
You can use any kind of steel. I have used O1 because it looks better, but no other reason. If I am making a small tool, I will use O1 because I use the rod as the cutting tool (no cutting bit) I heat treat it to hold a better edge. You can use cold rolled with no issues.
Steve
Re: John Lucas
Ditto what Steve just said.
