Sanding boxes with wax questions.
Galen Vetterick
I watched Ray Key's "The Basic Box" video and it is the first time I have seen sanding through the grits with wax on the sandpaper. He noted the use of wet/dry silicone carbide papers but did not say what type of wax was used, It looked like a very soft paste consistancy. Since he said the boxes were turned at 1200 to 1500 rpm he never notes if he slows the lathe to sand so I assume it is at the same speed. He says it reduces heat from friction and cut down on the dust. It looks like he puts on a different type of wax for the final finish but never really says what it is. Sure leaves a newer turner with queations why.
Is sanding with wax a very common practice on boxes or more just Key's method?
For those who do sand with wax what type of wax is used?
What do you put over the piece as a final finish?
Thanks if you can comment
Galen
