bobbing compound
bobbing compound
bobbing compound
Dave Staeheli
Didn't want to hijack the other threads, but my favorite buffing compound is bobbing compound. It is a kinda yellowish tan. I much prefer it to the Beale Tripoli, which can (for me anyway) leave a residue/smear behind. The bobbin seems much cleaner. Some say it is more aggressive than tripoli. What I really like about it though as it doesn't seem to get clogged up in the pores or leave stains behind like tripoli does. Or at least its a lot less noticeable.
I can't say where to get it. I got my piece from a horn and bone craftsman. But I see it out there available from jewelry supply sources. My craftsman friend started using it after finding out that it was one step that Browning Rifles uses on their rifle stocks. And can't get much nicer than that!
Re: bobbing compound
Dave I saw bobbing compound listed but couldn't find any info an where it stands in relation to all the other bars. I did find one place where it could be purchased in course medium and fine, whatever that means.
Carole Valentine
I am a bit baffled by folks who say their compounds leave smears behind. If that happens, it seems to me that there is just too much compound being applied to the wheel. It takes very, very little to do the job.
Correct, Carole!
Bill Howatt
Me Too Carole
Barbara Gill
Russ Fairfield
Stating particle sizes can get me into trouble, because different abrasive materials have different cutting properties, and different manufacturers have different specifications and tolerances.
We are always treading on thin ice when we talk about buffing compounds for polishing wood and finishes because we are using products that were made for polishing metals. Using them on wood and softer wood finishes is a relatively new technique.
In Tripoli Compound, the abrasive particles use tallow as a carrier. When too much compound is used, that residue is the same as smearing lard on the wood.
One thing for sure, we all use too much polishing compound on our buffing wheels.
Bobbing compound cuts faster than Tripoli because it is a coarser grit. Tripoli is Jewelers Rouge and that is the same particle size as an 900-1000 grit sandpaper. Bobbing Compouind is closer to what we know as a 320 grit particle size.
There is also a Yellow Bobbing Compound that also uses animal tallow as a carrier, and (I am relying on memory here) it is a finer grit that is similar in particle size as 600-grit sandpaper.
Ditto
other than the shape being work my buffing wheels look new except for the tripoli which has slight yellow color.
Russ I'll have to go back and look at some of my notes from the other day but I believe it said Jewelers Rough was a higher quality abrasive and I think finer. It is used for gold and silver because it doesn't cut as fast as Tripoli which is designed for harder metals like steel and chrome. I still have more research to do but it's kind of low on my list right now do to other pressing matters. It was just a fun thing to do to kill time while I played receptionist.
Talc
John Kaner
I read where you have smearing from buffing compounds to sprinkle on some talc and buff to remove excess. Something about too much pressure leads to problems...
