Message for Ellis, RE: Klingspor
John Kaner
Hi Ellis,
Made a phone order to Klingspor on 3/3/10 using the $5.00 Off $35.00 or more code WCTR12. I made this order as I support WoodCentral and I saw their ad on the turning page. I also heard how good their paper is. I don't mean to whine and complain, however the facts are I'm not happy...
Received the order yesterday and the box must have been drop kicked to Alaska!
I'm going to attempt to load pix of the box. It was all taped under the plastic strapping... Look like a used box...
Did Not get the $5.00 off. Called and asked and that code is not in their computer.
I told her if you make a web order it accepts it. We don't use web orders anymore as we got burnt, changed card and got burnt again...
She agreed to refund the $5.00 to our card, but this time only!
I felt like a thief and that hurt.
Re: Message for Ellis, RE: Klingspor
Sorry for your trouble
I'll pass it along to the Klingspor brass.
Re: Sorry for your trouble
fgvanatta
First of all, the problem with receiving the $5 discount was due to not using the web site. If you choose not to do so, that isn't the vendors fault. Second, the primary culprit for damaging a box like this is the postal carrier, not the shipper. All in all, I don't see where you really have a gripe with Klingspor unless there is a defect with their product or an insufficiency in the shipment. They did give you the discount even though you didn't order from the web, so maybe you should be praising instead of berating them.
JMO.
John Scheideman
The last time I ordered from Klingspor they honored the $5 coupon. I can't remember if I called it in or did it on the computer. The box I got was sort of beat up but everything from Klingspor was fine. I'm sure it was the fault of the carrier. I have never had any complaints about Klingspor at all.
John
