My original sharpening jig, that I still have, is the Glazer one that is long and made of wood. It pivots in a block of wood that sits on the floor. I have for some time now been using the Vari-Grind one that just about all my wood turning friends use. Still, I wonder if there may be some advantage in using the old Glazer contraption. Does anyone still use it? Are there any advantages to it? If there is, it would seem that it would have to do with the fact that the pivot is so much longer than the Vari-Grind arrangement, and that this long pivot could sometimes, somehow, contribute to a superior gauge shape when combined with the right angle, protrusion, etc. Any thoughts?
This is an excellent old jig, and until recently, would hold a gouge bigger than the Wolverine system. But Oneway has now modified the Wolverine so you can use it to sharpen your 3/4" gouges. I only ever had one problem with the Glazer jig. I had a dimple in the hardwood floor where I would locate the foot -- and I kept filling it up with sawdust.
Eliot when I started building my first sharpening system I had played with the jig. Consequently my first experiments were with the length and angle of the support arm on the jig. I found that the length didn't significantly affect anything. The angle did as well as how far the blade protruded from the jig so I decided on a standard length and played with the angles. I wish I could remember all the details but that was about 7 years ago when I had my basement shop. Making a long story short my homemade system ended up being extremely close to what oneway recommends in their instructions except the arm was about an inch and a half shorter.
I guess the engineering guys could plot some graphs and show us the differences.
I can see one advantage to the Glaser wood jig. Many yeara ago, I got the Glaser 1" spindle gouge - think German or Continental gouge, but very large and with a very long, heavy handle. It's best use is on very large spindles and hollow forms that have long sloping curves. I didn't know how to sharpen it, and at that time, I could not free-hand sharpen worth a crap.
A woodturning/metalworking friend made a larger version of the Wolverine jig and the V-arm for me. Works great, but (and this is an issue with all v-arms), the longer the arm extends away from the wheel, the greater the drop. So if you set the bevels against the wheel before you lock the arm, the locking will raise the arm, changing the bevel that you just set. If you are aware of this you can compensate by holding the arm up in the position that it would be when locked down. The old glaser floor model doesn't need the v-arm, so no issue.
I initially tried to write , 'Glaser" but kept getting spell check red underlines until I used, 'Glazer'. As for , 'LAZER', I don't see that anywhere in this thread.
The Glaser jig is a more natural movement than the Wolverine-it feels more like freehand grinding. The end result isn't better, just the feel. I have a couple, but no longer use them. One was one of Jerry's first. He used to send me one of everything. The other was made under and agreement, by Woodfast, and it;s a bit fancier.
I used a swing down arm on my grinder cart for the pivot-it's still on there.
John. You know, after thinking about it for a while, I sort of came up with what may be going on: the real difference between the original Glaser and, say, something like the Wolverine Vari-Grind, is the length of the pivot arm. Being a mathematician, one of the ways we often try to picture things is to take it to the limit. So I imagine the pivot to be as long as the depth of the Grand Canyon! So the pivot point is down at the base of the canyon, and I'm up at the ridge sharpening on the wheel. Then the change in angle when I turn the gauge from front to side is virtually zero. Such an arrangement would produce a grind that has the same angle all the way around. Whereas the Veri-Grind, with a pivot length of just a few inches, definitely creates a steeper angle as you come around to the sides of the gauge. Granted, of course, that the Glaser pivot arm is not quite so long, it certainly is longer than the Vari-Grind, and the principle is the same. The Glaser would produce a grind that is more nearly equal as you go around. Now the question is.....can you see some advantage to that? Maybe so.
Anyone have a picture of this jig? A longer arm is just what I need for my strip sander. I am curious as to how this would affect the shape of the grind. Anyone?
Carol. I think I can get a picture into my computer, but I'm not sure how to send it. I believe it's easy, but I just don't know how to do it. Can you tell me how?
That's exactly right. The vari-grind feels "stumpy", the long Glaser jig more natural. I guess it might be helpful to one really trying to learn to freehand, but it doesn't really make much difference.
No that is my 5/8" Glaser gouge. It may have been a set up photo to show the Glaser jig. But is is not at 90. I use about a 60 degree angle on the nose of my grinds. You can see it in the grinds library on this site. It is also to me the most natural grinding jig I have ever used. I went with the Wolverine when I started doing more demos. It seemed that it was available at most of the places I did demos. Less stuff to pack up and take along. But I still like the Glaser the best. I may even dust off the cobwebs and put it back into use.
