O.T. Hey engineer guys
Paul Zerjay
I want to quit paying for electric at outdoor art festivals. I'd like to ask if I have a 4 ft. track light that has 5 LED fixtures, can I power that with a deep cycle 12v marine battery and a power inverter? Would I need two 12v batteries? If I had two batteries, could I add a 110v receptacle? I'd like to put this in a box along with a charger that I could transport back to the hotel and recharge overnight. Am I asking for the world here, or is this do-able?
Re: O.T. Hey engineer guys
Steven Antonucci
Solar options or a generator?
Steven Antonucci
How about the solar driveway lights? Or could you run a small generator?
S
Re: Solar options or a generator?
Paul Zerjay
Think of this as a storefront display. Solar is out of the question. Right now I have 5, 50w halogens on a 4 ft track and I run the lights all day. Generators start out at $1K and are frowned upon by show promoters as your neighbors tend to complain about the exhaust.
Ralph
Do the math... 5 each 50 watt lights is 250 watts, for ten hours would be 2500 watt-hours. That's over 200 amps at 12 volts (big wires) for 10 hours or 2000 amp-hours
The inverter is cheap, the wire less so, that much battery is 1) heavy 2) expensive
I'd just pay the man
what is your current draw?
Paul,
You need to find what the power requirements are for all the light fixtures and the power inverter. If you know exactly what you will plug into the inverter you could run it with a DC amp meter in line with the battery and measure the exact current draw.
Assuming the LED light fixtures are 12 volts, check the total current requirements then calculate the approximate run time from the batter specifications. Battery capacity is given in amp hours. This means that if you used a 50 amp hour battery and your total current draw was 5 amps, the battery would run power your things for 10 hours. Add things up and divide.
However, the specs may be "best case". If I were doing this, I'd hook up everything to a single charged deep-cycle battery and see how long it actually runs. Then if you want three times that, add two more batteries in parallel.
This web page looks like it will explain everything:
http://www.boatsafe.com/nauticalknowhow/marine_battery.htm
Paul Zerjay
Hey Ralph, on average these high end shows are charging 50 bucks a day for electric. A 3 day show, 3 times a month adds up.
Re: what is your current draw?
Gil Jones
Paul,
I don't know how marine batteries work, but if they generate hydrogen during charging, I would not want that in my hotel room. Think "BOOM!!"
Dale Cook
Hi Paul, I fish a-lot therefore I have deep cycle batteries and I use them at shows. I use one more for when it gets really hot I use a 20 inch box fan and it will run all day if necessary. I have been thinking about running some lights too. I would buy one a-little bigger than you need to make sure there's enough power. I think I bought my inverter at harbor freight and have been buying my deep cycle batteries at batteries plus.
Ralph
So?
5 each 50 watt lamps run for 10 hours (a day) would require (for example), 12 each L16 Trojan deep cycle batteries weighing 119 lbs each, for a total weight of over 1400 lbs. Costing $3250 (PLUS shipping)
It would also require an inverter (Xantrex is one of the best) running $150
Plus you would need to charge those batteries, so you would need to pack them out of the show-hall, off to where ever you are staying, then charge them, every day
Since you need to charge them fast (say 10 hours again) you would need one charger per, a good (Xantrex) charger would cost $264 (EACH).. Costing $3128
It would also require about $100 in 0000 gauge copper wire
My SWAG, just for materials $6500.
Now, I'm guessing you would need someone to build the system. This is the type of work done at most RV or Boat repair shops, their rates run between $75 and $125 per hour. It would certainly take a day
Plus you would need carts to haul the weight
Like I said, just pay the man.
Ralph
Hydrogen not that big of a factor, however I know I would not allow wet-cell batteries in a show if I was running it. This due to the fact that if tipped they will spill acid.
So that pushes the original questioner from the batteries I just mentioned into AGM's, which boosts the price again.
I may not know everything there is to know about deepcycle batteries, but between owner an RV for 20 years, and working with really big batteries at work (like ones to push a 1000 HP motor), I know enough to know when something is not going to work
Richard Allen
Richard Allen
LEDs, as you said, is the way to go. You can get 12 volt LED lights and skip the converter (the converter is likely to consume more power than the LEDs).
I have a LED flood light which runs off 3 D cells. I can easily get 10 hours out of one set of D-cells.
All this to say that the amount of power you will need for lighting is dependent on the lights. Not all LEDs are the same in terms of cost, light output and power consumption.
You mention that you are currently using 50 watt halogen track lights but you don't mention what style bulb you wish use.
Paul I attend a lot of craft fairs. I see honda generators or battery packs. I haven't looked into it myself but those seem like the most popular ways to provide electricity to a booth. The Honda generators are usually on an extension cord 20 feet or so from the booth. They run very quiet. If I remember correctly the batteries were usually 1 or 2 car batteries.
(Message Deleted by Poster)
Galen Vetterick
Paul Zerjay
I have no clue what your talking about buddy. All I want to do is power a 4 foot fixture with 5 low voltage LED fixtures attached to it. I don't see my original post being that misleading, but I don't think that's gonna take 12 deep cycle batteries.
Paul, the problem is you didn't say what wattage your new lights would be, only mentioned your existing bank of 50 watt lights. Get some numbers on the new lights and you can see quickly if it is going to work, otherwise you are fumbling in the dark (haha). If you don't have specific new lights in mind, time for some research.
Ralph
The LED 1157 bulbs work purty good, except for a few things.
The big thing you need to get the type that is designed to replace RV illumination bulbs, not the ones that are designed to replace running lights. This is because the running light replacement bulbs are designed to send their light at right angles to the axis of the bulb, as opposed to in-line with the axis.
Running off batteries, they are fine, but the problem that RVers run into is that they are not designed for the over-voltage that a converter/charger puts out, so what happens if you try to run them off of AC and a converter, they will burn out (ask me how I know)
Also, modern inverters (DC to AC) are very efficient, even the cheap ones now operate at 90%.
Ralph
Correct John, the wattage came from the number he gave
If he goes out and buys LED bulbs, the cost of the power goes down, but the cost of the bulbs....OUCH.
A good LED 12V bulb runs $25 to $30 EACH, and that's only about 4 watts. I would guess he would need between 10 and 20 (hard telling, LED lighting can be tough, he might need many
110 V AC LEDs can run even more, up to $100 -EACH-
Still, plus batteries, chargers (inverters if 110V AC LEDs are used)
PLUS, there is the danger of acid (wet-cell batteries), hydrogen venting (wet-cell, AGM and gell-cell), etc. Nothing I would want to do indoors
Indoors, I would just pay the man
Outdoors I would buy an Yamaha EF1000 (at about $720 shipped), or a Honda EU2000 (at about $850 shipped).
The advantage of the generators is, house power backup. In point of fact, last night we used both Honda EU2000s (they can hook together) to run the refer and lights for about 10 hours, after the power failed.
Dick Strauss
Paul,
If you are willing to go with LED lights and you want to replace 250W of lighting, here is what I'd do. I'd buy 10 12V LED lights in the 3W range (they each replace a 25-35W light depending on light temperature). Then your total battery draw might be 30W or about 2.5A (30W/12V=2.5A) with no transformers (since the lights are 12V running off a 12V source) to cause power loss. A 150AH deep cycle battery might power your lights for 60 hours with no charging. However, for maximum longevity of the deep cycle battery, figure on using only 50% of the battery capacity. This means you should be able to run the lights for 30 hours with no charging if I'm not mistaken (150AH*(50% capacity)/2.5A)=30H.
http://www.ledlight.com/mr16-three-one-watt-ultra-bright-led-light-12-volt-ac-dc.aspx
http://www.besthomeledlighting.com/product/MR16-12-GU5.3-M-5W-W
The 12V LEDs sold at te sites linked above sell for $30 each and would pay for themselves in very little time (versus $150 per weekend). Before buying the lights, make sure that they won't have a problem with a 14.5V input that is common for a fully charged battery. I think it is worth investigating given your situation!
Here is another site selling for $24 each... http://www.plasmaled.com/mr16_led_light_bulb.htm
I have no connection to the company linked here nor did I do a search for the best prices.
Good luck,
Dick
20 amps, not 200
Doc Green
Ralph, I believe you got the decimal one click too far to the right. To get 250 watts from 12V is about 20 amps.
~Doc
Color issue with LEDs
Pete in Holland, MI
If & when you head out for LEDs, most "white" LED sources put out a milky white color with a tinge of green & blue. Your halogen lights have a more natural sun-light output. Thus, the colors of your objects will appear different.
You can buy 12 volt under counter puck lights in LED, but output will be weak.
Try the color appearance of your products under these lights before you dream further.
Brad Vietje
You may need LED's...
Brad Vietje
Paul,
I'm a solar system designer/installer, so this stuff is right up my alley, even if you never use a solar panel. There are portable power supplies with batteries and an ac inverter and all, but that's a pretty big load:
5 x 50 watts x 10 hours = 2500 Watt-hours, or 2.5 kWh/day.
Using batteries and an inverter for ac lights, you'll lose about 20% overall, so you'd really use more like 3 kWh. Using flooded, deep-cycle batteries, you could draw them down to about 20% (80% draw-down), but your batteries will last longer if you only cycle them down by 50%. That means to deliver 3 kWh, you need to store 6 kWh for a 50% draw-down. If you go with sealed (VRLA or AGM) batteries you can not draw them down by 80%, so you'll need to stick with the 6 kW+ size battery bank.
High quality 6v deep cycle batteries, often used in golf carts (like Trojan T-105's or similar) are usually 225 A-h @ 6V, so 2 of them = 225 A-h @ 12v = 2700 W-h, or 2.7 kWh (at 100% draw-down, which you don't want). Going to 4 T-105 batteries, you'd store about 5400 Watt-hours, which would be a pretty fair setup (56% draw-down). These are 72 pounds each, plus 2-0 cables, so you're looking at about 300# with cables, etc...
Then you need a small inverter, probably between 400 - 600 Watts. A modified square wave (a.k.a. "el-cheapo") inverter will be fine for halogen or incandescent lights (pure resistance loads), but for LED's or other sensitive electronics, a pure sine inverter will be a very good upgrade.
The price for all these goodies would be roughly $750 +/- with a modified sq. wave inverter, and probably around $900 - $1,000 with a higher quality pure sine inverter. Then you have to build a wheeled cart to move this stuff, etc...
SO -- if you look into a few LED spots or floods (careful here -- some are pure crap), you will spend a lot more on the lights, but a LOT less on everything else. LED's are now available in about 5 color temperatures, so you can get as nice and warm/cool/daylight color as you want.
Say you use 6 LED floods at 6 watts each... these will cost around $75 each, but your entire load calculation is WAY different:
6 x 6 x 10 hours = 360 watt-hours. At 50% draw-down, that would require 720 watt-hours in storage. Applying our 20% loss, you'd need a battery that could store 900 watt-hours, which would be a single 75 A-h 12 volt deep cyclle battery. For some additional head room, you could get a single 105 A-h 12-volt AGM battery for about $225. Then you add cables and a 300 watt PSW inverter (like the Morningstar SureSine 300), and while you still spend the same amount overall, you get:
~100# total
LED's will last ~50,000 hours if you get good ones.
much smaller package
use a LOT less energy to re-charge (and more quickly, too)
You might also get a very good lighting setup with 5 or 6 3-watt LED's or some other combination. LED's make an intense light that doesn't spread out in a wide pattern, so they are very directional -- more like spots than floods.
OR -- use 15-watt 12-v CFL's and do away with the inverter and the losses entirely --- you'd just need the battery (or batteries), some 10-ga wire, and some screw-in light sockets . These bulbs will cost about $15 - 20 each.
Good luck,
Brad Vietje
Newbury, VT
Brad Vietje
Re: Color issue with LEDs
Brad Vietje
Good Advice.
LED's come in a number of different forms (tubular, screw-in bulbs, M-10 or MR-16 bases, etc...)
They now come in pretty wide range of color temp's too. Warm tones (2800K), all the way up to blue cast (6500K). Somewhere around 4000K will generally be recognized as "white", but true daylight tends to be around 5600K -- rather blue. We tend to use a lot of warm-white lighting (~3200K) in our lives, so we've grown used to seeing things in a fairly yellowish light. We may take an object over to a window to see its "true" colors, but that appearance will vary a lot with the time of day.
So Pete raises a good point -- take some pieces with you to see what they look like under different light sources.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Re: 20 amps, not 200
Brad Vietje
Ya...
I think Ralph's numbers are off. By my numbers, 4 T-105's would just do it, so 4 L-16HC batteries would do it with lots of room to spare (roughly 9kWh).
Clear skies,
Brad Vietje
Green Works Solar Store
Groton, VT
