Use for WD 40
Use for WD 40
Use for WD 40
D. Hansen
a friend sent me an email with 43 uses for WD 40. One use was to remove water spots from a shower door, another to remove insect residue from car finish. I had just finished turning some very green and sappy Eastern Cedar and was still sticky from the residue. I wiped the visor and tools but as usual they still were damp when I came upstairs for a rest. I went back after the email and sprayed the visor and tools. Amazing the sap came off. The visor did not cloud and everything has that WD 40 shine and feel. I don't know the longer term effect but it certainly did the trick. Apparently one ingredient of WD 40 is fish oil or at least that is what I have been told.
Re: Use for WD 40
Re: Use for WD 40
GaryG in MD
That's a good one. Thanks. Armor All is also good for visors, etc.
FYI, the WD stands for "water displacement"
Re: Use for WD 40
Re: Use for WD 40
Wally Dickerman in Arizona
Some halibut fishermen in the NW and Alaska spray their bait with WD 40. They claim that they DO catch more fish.
Wally
Re: Use for WD 40
Re: Use for WD 40
D. Hansen
Yep Wally that was one of the suggested uses. If it does consist of fish oil formulations then using it to enhance bait would make sense. In some states the use of enhanced biats is not allowed according to the email I received.
Re: Use for WD 40
Re: Use for WD 40 *LINK*
Fred Holder
In the June 2001 Issue of More Woodturning, I published the following letter information from Don Thur:
I recently received the following letters from Don Thur a Canadian reader
of More Woodturning. I asked Don, where one could get liquid WD-40,
why not use aerosol cans, and where did he come up with the Big Discovery.
Here are Don�s letters:
For the past 1 1/2 years, I�ve been using WD-40 as a drying agent for my
green-turned burls which has worked wonders. I�ve used this method on +200 pieces without any major problems (am on my 4th gallon of WD-40); my loss rate is very low (5%). The burl work that I do ranges from 6" to 20", finished size. A big advantage with this method is that the WD-40 can be sanded off with no loading of the discs unlike wax emulsion or Peg. It is sprayed on while the work is still on the lathe and then put away to dry for 3-5 weeks at which time it usually registers 8-10% moisture. I dry all my pieces in a 4� x 8' insulated shack (my wife�s �former� ice-hut) which is
kept at 55 degrees F using a $35 thermostatic heater from Canadian Tire
Corp. WD-40 specifications say:
� Contain No Carcinogenic
� Contain about 80% Stoddart Solution
(petroleum distillates/mineral spirits) which is a major product in many popular
finishes we use according to Steven Russell, Woodturning No.98, pg.20.
Note: Don had several other letters on the subject in that issue.
More Woodturning magazine
Re: Use for WD 40
Re: Use for WD 40
Carole Valentine
Another use: When coring, I spray WD-40 liberally into the entire knife kerf (often several times during course of taking a core). Seems to greatly ease the passage of the knife through tough sections of the blank.
Re: Use for WD 40
Re: Use for WD 40
Charlie Anderson
Save our menhaden! Don't use WD-40!
Re: Use for WD 40
Re: Use for WD 40
Carole Valentine
No fish oil in WD-40 according to the MSDS.
We still need to curb the menhaden fishing though.
Re: Use for WD 40
Re: Use for WD 40
A friend of mine had one of the old Mazdas with the wankel rotary engine. The car sat for some time and he found the engine was frozen and could not be rotated. He poured WD-40 into the engine until it filled the combustion chamber, then let it soak and it eventually freed up the engine. Auto parts stores carry it in gallon cans.
Re: Use for WD 40
Juergen
Try this to next time you change a tire.
Another use of WD-40
Re: Use for WD 40
Re: Use for WD 40 - tires
Starting fluid probably works better for that.
Did you ever try to get the bead to seal on a heavy-duty tire? It's sometimes a real job without the proper equipment. I worked for an hour once remounting one of my tractor tires. Even the tire shop had trouble with some tires from my bobcat and they were using an "explosive" blast from an air tank.
Best thing I've found that doesn't involve fire is to wrap a compressive band around the outside - I use a 2" ratchet strap if available or a rope tourniquet on smaller tires.
Re: Use for WD 40
The ratchet strap worked for me. Having burned off my hair and eyebrows with gunpowder I wasn't really brave enough to try the explosive tire trick.
Re: Use for WD 40
Re: Use for WD 40
I've read several times of people using WD-40 as a penetrant. It isn't anywhere near as good as real penetrants and it leaves a residue that causes problems on delicate moving parts. It totally ruins a camera. I tried to repair some cameras that had been sprayed with this but finally just told customers it would be a waste of their money.
Years later when doing banking equipment repair my boss came from a typewriter repair and said he saw tons of typewriter damaged with WD-40. It loosens things up and they work for a short while, then they gum up and don't work anymore.
Re: Use for WD 40
Dick Hines
Re: Use for WD 40
Dick Hines
It will take the glue from the sticky labels that are on glasses and pottery.
Also it will help in getting pine sap off truck paint. BUT every speck of dust in two countys will collect to the spot where the WD40 was.
Re: Use for WD 40
Don Pencil
Re: Use for WD 40
Don Pencil
Use it for starting fluid on diesel engines
Re: Use for WD 40
Mike Stafford
True story.....
Mike Stafford
My dentist told me that he read a story in a dental journal where a man sprayed WD-40 into his wife's mouth to help her remove some dental floss that was stuck between her teeth....
I'm not sure how that works as it would seem that the dental floss would become to slippery to grip.
Re: Use for WD 40
Kerosene
Russ Fairfield
There is nothing that can be done with WD-40 that cannot also be done with Kerosene, and 1K-Kerosene costs a lot less that WD-40 the last time I looked. Anybody who uses charcoal in the BBQ already has the kerosene in the can of fire starter which is nothing more than 1K-kerosene at a higher price.
Kerosene will never form a hard scum on the surface of a piece of metal that it intended to protect from rust. WD-40 will do that.
Re: Use for WD 40
Re: Use for WD 40
leadpipe58
WD 40 on Bait is a NO NO in P.A..So you know it works.
Re: Use for WD 40
Plus it gets really exciting when
you use a torch to burn a bowl. :D
Re: Use for WD 40
Kerosene vs diesel fuel
What's the difference between kerosene and diesel fuel? I know diesel has more carbon atoms in the chain but it seems close enough for many uses.
I sometimes use diesel fuel for cleaning, fire starting and such. It's a lot cheaper than kerosene and I usually have a 55gal drum on hand.
Re: Use for WD 40
Ken Vaughan
Re: Kerosene vs diesel fuel
Ken Vaughan
The fuel guy says that JP is a bit heavier than Kerosene and #1 Desiel is a bit heavier than JP but close. They use #1 instead of JP on refueling the jets and they run either way. #2 Diesel is heavier and less much less flamable than #1. There are enough blends that they blur somewhat.
Use of #1 in a kero stove works but is a bit smokier (often done here in the north as #1 is more available).
