Midsize lathe to buy????
A friend wants to buy a midsize lathe. Wants 12" swing and to turn mostly bowls. Something in the $700 neighborhood. Would consider used. (near Richmond, VA).
What would you look at?
Re: Midsize lathe to buy????
Your parameters are very limiting
Ed Moore in SW VA
For that swing and amount I would look for a Delta 46-460 12-1/2" Variable-Speed MINI LATHE. People who have them have not complained. The 1 HP motor and variable speed would seem to work for bowls that size.
Ed
Greg
I might suggest the new Delta mini/mid with electronic variable speed and a short bed. I believe it is 12 swing and 18 spindle. Or another of the 12" swing mini lathes like ones from jet or rikon
Don Pencil
Don Pencil
Jet / Delta in the $700 range.
I turned on a Jet 1236 for a long time. Still have it. Served me well.
Don
Philip Morris
Barry,
The Richmond VA Craigslist has a Jet 1236 that appears in nice condition for $300. The model has it's limits, but not bad for the a low entry fee.
Alternatively, your friend could possibly buy an older PM or Delta "school" lathe from Dempsey & Co. there in Richmond and add a VFD inverter.
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
I always remember seeing Bob Stocksdale on the cover of the first issue of Woodwork turning on a Delta 12" with riser blocks under the head and tail stocks.
Roy Girolami
JohnKyler
Delta 46-460
Sold a lot of them and they have been doing well.
Check with your local dealer
Ditto what Greg said. The Delta is less than $700 although if you add a stand and maybe a bed extension it gets to be more. It's a much better lathe than the early 12" full size lathes that sold for $400 20 years ago.
Brad Vietje
Delta Midi or Used PM-90 or PM-45
Brad Vietje
A used full-size machine will provide a much more stable platform and much more mass. Failing that, I'd agree -- I like the new Delta Midi.
I'll disagree with Don and others -- I have an older Jet 1236 (blue -- should be black and blue!), and it's not a lot better than a boat anchor! Apparently, I have a lemon, and many people like the %#@^&* things, and I DO remember being so darned happy with it when I got it, so maybe I'm just a whiner!
Safe spinning,
Brad Vietje
Newbury, VT
Re: Delta Midi or Used PM-90 or PM-45
Gordon Seto
Brad,
You are not alone. I upgraded from the Jet 1236 to the Jet mini 1014 VS. The 1014 runs smoother than the Reeves drive of the 1236. Gave up some capacity but is more enjoyable to use.
Brad I did the same thing, sorta. I "upgraded" from a Delta 46-715 (12" by 34" variable speed lathe) to a Nova Comet mini lathe. It was much smoother that my turning improved overnight. That's why I like the newer mini lathes vs the older outdated inexpensive full size lathes.
