Method of work
Steven Antonucci
For starters, the wood is anything but flat. Most of the boards came out of a kiln case hardened and distorted.
My approach to making these quickly is pretty straightforward. I start between center with a bandsawn disk of wood. I do a quick flattening of both sides using pull cuts from the face until I am 90% flat. Decide front and back, and then turn a very small tenon on the back (1/8"). Maybe 15 minutes.
Once it is in the chuck, it's all finish cuts and details. By making those cuts cleanly with sharp tools, I started sanding at 180, 220, 400 (couldn't find 320) and I had the entire face and 80% of the back done. I reversed it in a second chuck which has cole jaws in it to finish off the tenon and finish sand. I put some newspaper (a few sheets) in between the plate and the cole jaws to protect and cushion the leafing. Finish turning: 15 minutes. Sanding: maybe 5-10 minutes. Leafing: maybe 10 minutes. Finish: maybe 10 minutes over 4 hours.
As this is going to a gallery (for sale), I didn't want to invest 4 hours into a piece that will probably sell for $50-75. I will see how it does, and then if the gallery requests more like it, I know I can make them fast enough to justify that cost. While I am happy with the results, I think if I had to make 5 of them, I could do it in about 3 hours...
Steve
