sandpaper
patrick stein
hi everyone,
just wondering what brand sandpaper you prefer and why?
sandpaper
patrick stein
hi everyone,
Re: sandpaper
Norton 3X for my flat paper and the Blue discs from Vince's wood-n-wonders.
Re: sandpaper
fgvanatta
Rhinodry - cuts faster and smoother and lasts longer than anything else I've used.
Frank
Re: sandpaper
robo hippy
Blue discs from VincesWoodNWonders.com They outlast just about every other disc I have tried at least by 2 to 1, with the exception of the Dry Ice discs from Norton which cost more than twice as much. Norton 3X for spindles. Good price if you buy the 50 sheet packs, and it lasts fairly long.
robo hippy
Re: sandpaper
Jeff Willaford
Norton A275 velcro backed discs from Bruce Hoover, The Sanding Glove. They seem to work well for me and I like the flexibility of the disc.
Re: sandpaper
Cyril Griesbach
Klingspors "Rolled Gold" and Vince's blue discs. Because they work.
broad question
Patrick,
Different papers work better for different purposes.
For general spindle turning, I like the rolls of Klingspor gold, up to 400 grit. I love the rolls since they are easy to access - I mounted a rod over the lathe and tear off little pieces as I need them - I mount a 2" roll next to a 1" roll for each grit, separated by thin plywood disks:
Most small spindle turnings don't need paper finer than 320 or maybe 240, so the rolls of coarser grits last forever!
For finer grits, my favorite is Rhynowet. I keep 600 - 800 - 1000 - 1200 grits cut into strips about an inch wide and maybe three inches long, kept in little plastic bins (shown in the photo but not yet loaded up.) I cut up about 20 or 30 pieces of this at a time and write the grit number on the back. This paper is great - it's tough, wears well, easy to clean if it loads up, and can be used wet or dry. This paper also folds well, better than most - I usually fold the one inch wide strips in half which makes a strong edge for getting into tight spots. The binder used in some sandpaper is not as flexible causing the abrasive surface to crack when folded.
For bowls and bigger stuff, the 2" disks of Klingspor gold work fine for me. I've tried other brands and except for some I bought at Woodcraft, most worked fine. I don't do as many bowls as spindle work and end-grain boxes.
Ditto
Steve Kubien
Re: sandpaper
Mike Mills
1+ for Indasa Rhynodry Redline (Roll) Very consistent (leaves fewer scratches). Last a long time.
+ for Vinces blue disc. For me works better than the major woodworking stores brand.
Mike
Re: sandpaper
patrick stein
thanks everyone,
I think I will try the blue disc from vince.Iuse the wavy disc from woodcraft.I do mostly bowl or vase turnings.
Re: sandpaper
Scott Hurley in N VA
I've fallen in love with Abranet/Abralon. You can get in sheets or disks. It hardly ever clogs, and if it does, just flick it with your finger to clean it out. Check out 2Sand.com - he has it in 3" disks for H&L. You'll need an interface pad, also.
Scott
