A Day Long Demo By John Jordan
charllie belden
My head's still spinning going over all the things John shared with a group of about 30 of us during his day long demonstration. Starting with a recently cut half logette - and the importance of making choices from the get go which will determine the options for the look of the final piece - to the last hour of carving and texturing tools and techniques - it was like trying to drink from a firehose. So many subtle and usually overlooked little things to consider all along the way which can take a fair piece to a good piece, or a good piece to a really fine piece.
After roughly turning the blank, which he'd oriented to leave some light sapwood on the neck end of the hollow form he was after, he recentered the piece a bit to get rid of some light wood that would otherwise show up at the waist of the piece he was after. And he changed the centers to minimize reducing the max diameter of the final piece. Subtle little thing - but meant a larger final piece - and the proportions he was after. Things like that would never have occurred to me and I'd have turned a nice shape - that didn't look as good as it could have looked. The day was full of John pointing out little, but very important, things like that.
And it's all those "little" things that we don't think about, or take the time to do like:
Maintenance:
Touch up the tool rest so it's smooth and lets the tool glide over it, waxed periodically so a tool will slide over it. Any interruption in the flow of a cut WILL SHOW - if you're turning green wood start to finish.
Wax the tool shaft where it'll contact the tool rest. Again,a little thing that can mean the difference between a fair curve - and one that's not.
Keep the lathe ways (sp?) clean - and WD40ed - so that the banjo slides effortlessly when you need to move it.
Clean off the male morse tapered centers - AND the hole they go into - to avoid one source of run out.
Green wood turning means snugging up the tail stock regularly. He doesn't lock the tail center down, but regularly snugs it up as he turns. If you lock it down you'll forget about it - and ASSUME it's good. But with green wood it WILL get loose over time - and then things can move that shouldn't. Knowing that the tail center isn't locked down means checking it regularly. Makes sense - once you've had it pointed out.
Clearing the chips out of a hollow form often. He's got a long little rod with a little hook on the end for getting the stringing green curlies out of the hollow form, then blasts of air to blow out the little stuff. As soon as he feels his hollowing tool begin to chatter he stops the lathe and clears the chips. So THAT'S what often causes my cutter to chatter - DUH.
Wood Movement
John kept coming back to how green wood moves as it dries. It will change little along the grain, most acrossed the grain and less between the growth rings. Will it go oval or egg shaped? Depends on how you mounted the blank originally. And that depended on how the grain was oriented in the original logette the blank was cut from. Where you start from will determine where you CAN go - because the wood is going to do what it needs to do as it dries. That understanding can mean working WITH the wood rather than AGAINST it. In the end, the wood will usually win - so go with a winner.
The list goes on and on - and that's just skimming my notes. It'll be days of studying notes and photos before I'll "get" a fraction of what he showed and told us.
Folks, you can see a ton of photos of Johns pieces but until you've actually seen - and carefully held - one you really can't appreciate what this Tennessee boy creates.
I found my "Life's Too Short To Turn Crappy Wood" T-shirt and John was kind enough to autograph it for me. Dropped a chunk of change on a set of his 1/2" and 3/8" hollowing tools and a short handle, along with the little sharpening jig for the replaceable cutter tips.
If you get the chance to see and listen to John in action - don't miss the opportunity. I promise you, it'll be time and money well spent.
That's a good group, and you're lucky to have Rich's shop to meet in.
