Ambrosia Beetle
Ambrosia Beetle
Ambrosia Beetle
Charlie Anderson
Is there a way to tell if a maple has beetles without cutting it?
A friend is going to remove a maple (unspecified type) in the Baltimore area. It's about 30" in diameter at the base.
Re: Ambrosia Beetle
Re: Ambrosia Beetle
Guy Bratt
Usually you will find small holes in the bark about the size you can see in the stained wood. sometimes the tree will leak sap or you might find small spikes of sawdust at the entry location. There are several kinds of beetles in different locations. Check out your county extention service.
Re: Ambrosia Beetle
Re: Ambrosia Beetle *LINK*
Guy Bratt
maybe start here
ambrosia beetle
Re: Ambrosia Beetle
Re: Ambrosia Beetle
jim miles - Charlote NC
Foresters use a core sample- to determine age & health of trees. It is a small hollow drill bit that is drilled into the center of the tree and a core sample is removed from the bit. Don't know, but I think this would show ambrosia.
