HELP, Finish over dyes
Norm smith
Please help. First time using dye. I applied artisan alcohol base dye on a piece and than applied lacquor. I sanded lightly than applied wax. The problem is that the dye bleeds through. I suspect that the dye must be sealed. What are the proper steps and what is the proper finish for these dyes?
Thanks,
Norm
Re: HELP, Finish over dyes
The alcohol soluble dyes are soluble in your lacquer which uses alcohol as a solvent. I typically use a sanding sealer without alcohol to seal projects that I dye. I will also use an oil based product as the finish.
Generally speaking - like dissolves like. Therefore you use a product that has a different "base" to seal.
Can shellac be used? ++
Norm smith
Thanks JL,
Can shellac be used as a sealer for dye and can lacquor or oil be applied over the shellack?
Thamks,
Norm
Keith Tompkins
Re: Can shellac be used? ++
Keith Tompkins
Norm, I would say yes, but test on a sample first. Look for the highest quality, clearest shellac. Brushing in on evenly will be a challenge, and will require sanding to level. Thinning with alcohol will probably cause the same problem you're having now. I'd rather spray sanding sealer with a detail gun or airbrush, then lacquer.
Richard Allen
Richard Allen
Use a waterborne finish for solvent base dyes. If you want to use solvent based finishes use water based dyes.
Many dyes can be used with either water or alcohol.
When using water based dye be sure to raise the grain on the wood a few times before putting on the dye. The raising of the grain (and sanding off) should be done fairly soon before applying dye.
You can try fast drying spray finishes.
