Re: Big Mac & The Mirror
Mac Ray
Jorge hit it pretty close......poplar glue up,eight sided,three layers,takes two Bubbas to lift it,turned at somewhere in the range of 150 rpm,slid belt down to the lowest speed in order to get extra torque,lathe handled it just fine and could handle much more I'm sure...............even with two layers of plywood for a mount,there was some flex when using a parting tool to cut grooves,more speed might have remedied that but I wasn't up to more speed..........a fun spin......everyone should give it a try.......had to slow it down with the speed pot before turning it off,if you just turn it off,the safety on the computer puts it into free wheeling and it takes forever to stop spinning....and you have to reset the computer.....not a problem,just a pain......remote switch is very helpful on something like this......you can place it anywhere its handy, in case you have to shut it down suddenly...I would recommend it for all lathes as safety equipment......give it a try sometime,you'll like it........:)
