Thin bowl drying time.
I had this scrap around the shop and wanted to do an experiment to see how long it takes to dry. I turned it 1/8" thick except for the bottom. Where the feet are it's a little over 1/4" . It dried to where it isn't losing weight in 18 hours and that's with a good rain outside to add some moisture. I dried it in the house overnight.
Re: Thin bowl drying time.
robo hippy
1/4 to `/2 inch thick bowls dry for me in one to two week, depending on wood and thickness. I can see that if I did 1/8 inch thick and took it into the house, which is dryer than the shop, it could be dry enough to sand in a day.
robo hippy
Fred Holder
I did a test a year or so back on drying time. I used Walnut root and turned two small bowls (about 4" in diameter). I soaked one in DNA overnight and then wrapped it in brown grocery sack up over the rim, leaving the inside open to the air. I also wraped the unsoaked bowl the same way. I weighed each of them daily and recorded the weight. The first few days the DNA soaked bowl lost weight faster. As I recall, it took about 14 days until both stopped losing weight. They did this together. The only difference I could notice between them was that the DNA soaked piece turned a bit better for the final turning. I was very surprised that both dried in the same length of time.
How thick were they Fred?
Re: How thick were they Fred?
Fred Holder
They were turned to about 3/8" wall thickness.
