table glue up
I finally got the table glued up. What a hassle. After assembling the top which had the 24 spindles I decided it was too risky to glue it up by putting glue in the one side and glueing all the spindles, then trying to put the other side in. If anything didn't align perfectly I would be screwed.
I decided the best course of action was to mix up epoxy with thickener to the consistency of peanut butter so it would not run. Then I could epoxy the top and the ring and put all the spindles in. That would give me a fudge factor if anything didn't align just right.
It actually went better than the dry runs because the epoxy was a little slippery which made sliding the spindles in the holes easier.
I had to weight one side of the bottom glue up because I couldn't get clamps on the workbench side.
That was a load off my mind. Now I just need to screw the bottom to it's brace and the top to it's braces and I'll be done. No actually I have to apply some more finish to the top. I had 4 layers of finish on the top before I could see some little swirl scratches that had to be from the first grit. Bummer. I looked hard for those things. Anyway I sanded off the old finish and started over. It looks better now but needs about 3 more coats on the top.
Actually there one more thing. That dreaded leveling of the legs. It may be 6" shorter by the time I get that done.
