Dawn redwood?
Dawn redwood?
Dawn redwood?
Anyone turn dawn redwood?
I have some logs I think are dawn redwood. Someone gave me the tree which was over 24" wide at the butt log. I sawed a couple of hundred board ft into 1x12 boards and used it for interior shed walls. The wood is an amazing soft pink color, light in weight, slightly aromatic - the smell reminds me of eastern cedar.
I may cut some big pieces and slabs to try out on the lathe. The books say dawn redwood doesn't have much lumber value since it is soft and brittle. Tearout might be a problem. The color is unlike anything I've ever seen.
Any experience with this wood?
Re: Dawn redwood?
Not for the faith of heart
Dave Smith, Longview, WA
Hi John,
Dawn redwood is PITA to turn. I like to toss large piece to people and watch their reaction when they catch what they thing is a piece of styrofoam. It seems to be unsinkable. I soaked some green pieces in alcohol and it never submerged.
The best solution for turning was to soak the roughed out dry piece in thinned lacquer to stiffen the fibers. Reapply lacquer when the fiber begins to tear out again. You need to do finishing cuts while roughing out because the end grain tear out is so severe. Excessive sanding will quickly render a washboard surface.
I finished a couple of bowls turned from root with deep gloss lacquer. The color and figure are spectacular but the wood mars too easily for practical use. I could turn solid Christmas ornaments that would be lighter than hollowed ones.
Dave Smith
Only a couple of weeks left in the winter quarters of Mesa, AZ.
Re: Dawn redwood?
Bill Blasic
Re: Not for the faith of heart
Bill Blasic
John,
One of my club members had an 80' Dawn Redwood that had to come down. I went and got some of it and I found it a dream to turn. I neglected to go back and get more and when I remembered to go back it was all gone to chips I suppose. I know my experience sounds different than Dave's so just give it a try. The tree also has an interesting history.
Bill
Re: Dawn redwood?
Charlie Anderson
Aha! So that's why you included dawn redwood in my care package.
I got two pieces. The first oneI blew up. The other is still on the wood shelf waiting it's fate!
Re: Dawn redwood?
We know that wood is widely variable from tree to tree, so perhaps some is better for turning than others. I've turned some eastern red cedar that tore out badly and other pieces that cut cleanly.
Or perhaps the dawn redwood turns great green and tears out when dry. The wood I have is light in weight but dripping with moisture. I think I'll chuck up a big chunk and try a platter or bowl.
Re: Dawn redwood?
Bill Blasic
Bill Blasic
John,
Funny but my Dawn Redwood is very heavy. Does yours have stringy bark that is laced with red coloring when pulled off? A deciduous Pine type tree was new to me as I didn't know there were Pine types that lost their needles every year. I sure wish that I had taken a lot more.
Bill
Re: Dawn redwood?
different woods?
Bill,
I didn't see any red coloring under the bark but I didn't peel any off - I just put the logs on the sawmill and squared them up into cants last year then cut boards for the first time last week. I've burned the most of the outer pieces with bark although there is still some bark on some 1" boards with wane I could try to look at. The sapwood is white.
There is, of course, the possibility that either mine or yours or both are NOT dawn redwood! (Metasequoia glyptostroboides) I based my guess at the species from the light weight and the color (compared to some pieces Dave sent to me a few years ago), the size of the tree, the presence of dawn redwood trees in the area of similar size, and the fact that I could not find a trace of evergreen needles/leaves in the area where they felled the tree in the early spring, indicating it was deciduous.
That you said yours is very heavy makes me think it may be something else. The references I found universally mention the light weight of dawn redwood. The only specific gravity mention I could find was from Dr Wengert on the Woodweb - he said the green SG was 0.27. By comparison, from one chart I found green black walnut is 0.91, soft maple is 0.80.
I don't have a reference photo of the crossgrain since it is not listed in Hoadley's book. I will try to compare what I have to what I got from Dave under the microscope later this week. Do you still happen to have a tiny piece left over? - all is needed is about 1/2" square of end grain.
Re: Dawn redwood?
Mike Stafford
Mike Stafford
Dave, I don't know if you recall but you sent me a couple of very dry pieces of dawn redwood several years ago. I turned boxes from both pieces and although it was light in weight and somewhat soft I was able to turn boxes from it.
I think I sent one to you....
Re: Dawn redwood?
Bill Blasic
Bill Blasic
John,
Yes I have some, do I slice across the end grain and then take a photo? The person that had the wood planted it in 1954 and told me a little about the history of Dawn Redwood.
Bill
Re: Dawn redwood?
wood ID/comparison
Bill,
You can take a razor blade and shave across the end grain. Hoadley's excellent book, "Identifying Wood" describes this and shows pictures of many species.
Hoadley recommends a 10x hand lens to examine the pore and ray structure. I use a low power binocular microscope, 15x-30x. I can take a photo by holding up a digital camera to the eyepiece, as I did with this sample that someone on the forum sent to me a couple of years ago. It's not as sharp as one taken with the proper equipment but it's certainly enough to work with:
In this picture you can easily see the ring porous structure and the wavy bands of latewood pores characteristic of elm. Note that it's usually easier to identify the general group "elm" than it is the specific type of elm. She (sorry, I forgot who) also sent a piece to the government's free wood ID program and they wrote back and said "elm".
A good macro lens on an SLR might work but I haven't tried that.
However, most of my examinations have been with hardwoods which usually show clear pore and ray structure. Hoadley mentions that softwoods are often more difficult to distinguish, sometimes requiring examination of the cells themselves with a high-power microscope. I don't know if the redwoods are like this - I haven't paid too much attention to that part of the book. If that's the case, I may be sunk in making an ID but we could at minimum compare our two pieces and perhaps with what Dave sent me if I can find it.
If you can send a picture of what you have I'll do the same. Or even better (for me!) is if you mailed a small piece of the wood itself. That would make it easier to compare side by side and do other tests if necessary. (I had to use blacklight on a piece last week - a few woods fluoresce under UV.) If you do send a piece it only needs to be about 1/2" square across the end grain and maybe at least 1/4" thick to give enough to grab onto. A slightly bigger piece could be oven dried and weighed to get a density measurement.
BTW, any comparison would be more difficult if one of the samples came from a burl or root or some other less usual area of the tree.
Another option is to send a piece to the government lab for ID. They will ID up to five pieces of wood per year for any US citizen. I can look up the address and details if you want to try this.
Re: Dawn redwood?
Box
Hi Mike,
The box you sent me is silktree, commonly called mimosa. A beautiful box I take pleasure in showing off.
Dawn redwood has pale red or pink heart wood.
Dave Smith
Wintering in Mesa, AZ.
Re: Dawn redwood?
The tree was growing in my front yard.
The first fall in our house the needles fell of the tree. I thought I killed it. It turns out that dawn redwood drops its leaves. I have pictures of the tree before it was cut down. I may not have them on my laptop. You may need to wait until we return home for pictures or a wood sample.
Dave Smith
Sunshine today in Meas, AZ.
