Re: Powermatic arbor replacement
Mac Ray
It seems that the boys had a bit of a problem when they put the faceplate on the arbor....it was attached to a 4' glued up disc mounted on plywood and they got it cross threaded...pushed their luck a bit too far and then couldn't back it off either.Even a machine shop couldn't remove it....the spindle suffered quite a bit during all this and the bearings seem to have a headache also....................along with the spindle lock and the index lock...looks like all new parts are in order,in the meantime,looks like I am going to turn the mirror frame for them...am mounting it up tomorrow on my OW and hope I have better luck,it will take two of us to get it onto the lathe........maybe I will take a pic of it when it's done.......this is the first of many that they have to do,so I'll do the first one and hope they get their lathe up and running soon.....thanks all for the sources for parts,I sent them on .....
