I didn't want to hijack Jennifer's threads so I thought I would start a fresh one....
Ed in Leaside graciously provided me with a manual charger and "helped" me add a dimmer switch (ok, he wired it while I watched). So now I am on to pens and I've got a problem.....
I have followed Molly's directions on making the pens, got the nichrome wire, all is good right? Wrong. The brand heats up nicely and then the whole thing shuts off. Give it 20 or 30 seconds and it heats up again but only for enough time to use the brand for one or two marks. Then it's off again. It took me about 10 minutes to brand an area about 2" square. Is this typical? I wouldn't think so or no one would go this route.
If it makes any difference, I've got 14/2 wire coming out of the charger and 18/2 or 16/2 lamp cord for the pen. Should I be using heavier cable for the pen?
Steve, it sounds like your pen is drawing more current than the charger can provide and an overload protection device in the charger is kicking in. I am guessing that you are using too large a gauge of nichrome wire or too short a piece in the tip for the intended purpose. In other the words, the resistance in ohms of the pen tip is too low to match the capabilities of the charger. The power P (heat) dissipated in the pen tip is equal to VxI, where V is the output voltage of the charger and I is the output current. However I is equal to V/R, where R is the resistance of the tip. Therefore, a given power P can be obtained with many combinations of V and I, controlled by the value of R. In practice, you are limited by the maximum output voltage of the charger and the maximum current that it can handle without overheating. I would suggest that you run an experiment using a finer gauge of nichrome wire to see if things work better. Dennis
I have had a real journey with my burners I can tell you .I could right a book
Steve Graham made me one up that we used in Austrialia at an event we not only fried the transformer but the dimmer as well ,we had real trouble getting a manual battery charger and an even harder job getting the right dimmer
I have since had another wired up and it works a treat with
12 amp charge type without auto electronics , dimmer 700 watt leading edge
I suspect your dimmer is the problem not a leading edge and has electronics in it
I believe they are the same as what used t be used in the old cocking stoves
Glad I'm not the only one. I tried to build one a year ago with a no name charger. It was simply the lowest priced one they had. I assumed it would not have any electronics. It simply would not heat the element period. I tried heavier and lighter gauge Nichrome wire and it still didn't work. I turned it back into a battery charger and bought one of the Napa chargers but have not had time to wire it up. I suppose it could have been the dimmer as Tery said. When I wire up the NAPA I'll find out because I still have the dimmer.
If the cable to the pen were the problem it would likely be getting hot. What gauge is your nichrome wire? Does it work if you use a store-bought woodburning pen? It's always possible the charger is bad - does it charge a car battery OK?
If the nichrome wire is not too heavy gauge, double check that the charger has no electronics inside other than a rectifier. It should have a relatively big transformer, a rectifier, a thermal/current overload protector, and some wires and connectors. Perhaps you can post some closeup photos of the inside of your battery charger.
This article has a photo, but it doesn't show everything:
In I think 2003, I built a unit from plans I downloaded from Ed Walicki at Fishcarver.com . They are no longer on his website. It was essentially a Radio Shack Center Tap step down transformer rated at 12.6 volts 3.0 amps on the output side. PN 273-1511 His plan incorporated a light dimmer on the input side and the output side. The one on the output side did not work at the reduced voltage, so I removed it. There is no diode rectfier so it is low voltage AC. I have used with a pen I bought from Lee Valley that will take custom made wire tips. So far has worked for me although I have not tried with a heavy branding coil type tip. I have the original file if anyone wants to try it. Not terribly complicated electrical work. Based on it's design you could probably use the step down transformer and rectifier in any battery charger to build a unit. I would expect that the transformer in a battery charger would have much more beef than the Radio Shack unit. Lincoln Electric might be another source for a basic charger. They were selling a bunch off at the Canadian Home Workshop Show in Toronto last weekend.
May I ask , what is wrong with a store bought burning system? I use a detailMaster and pens I made from the information Molly sent me. The Detail Master does a great job and GREAT is all I can say about the pens Molly uses.
from the input side, as they built it to draw whatever current it needs. I don't know if you have a little needle to indicate the amperage, but I usually run mine at 1/2 power or I need welding goggles to look at it. Mine will trip too if I draw too much current.
I used heavy duty "monster cable" speaker wire for the pen. Your pen wire should probably be the same gauge as the jumper leads, and your nichrome can be whatever gauge you want, but the thinner stuff cannot carry as much as the thicker stuff, so you have to be sure that your dimmer is wired correctly.
If you have a little needle, it should move up and down when you turn the dimmer. If it doesn't, that's your issue. No needle? put a meter on the leads and check the output...
The difference is that the converted battery chargers are being used as high-current wood 'vaporizers', not simply functioning as woodburners or pyrography "machines" (now there's a mis-use of a word!) with standard woodburning"pens". Nothing is wrong with the Detail Master unit that you have (I own one myself), but it lacks the higher current delivering capabilities to do the wood vaporizing ("pyro-carving") that Graeme Priddle has been doing and demonstrating for some time.
These units have different purposes requiring different electrical supply conditions. The converted battery chargers are just capable of delivering more current to enable higher temperatures with thicker gauge nichrome wire.
I know Molly uses a Burn Master unit for her branding and it does a great job (of course, so does Molly). The reason I am going this route is simple...I am cheap. I may still end up getting a Burn Master as I suspect it will be better for more controlled work like fine lines and smaller patterns. Who knows.
Fired it up (no pun intended) this morning after reading your responses. I went through the links John K Jordan listed and seem to have found the solution. One of the articles (can't remember which, sorry) mentions that Mr. Priddle disconnects a certain wire inside the charger (can't remember what it is, what it does or what it connects to. -sigh- I hate electricity.). Life seems pretty good now with a 20g nichrome wire brand, which I made a little longer at someone else's suggestion.
Here's a pic of the mess I made on an already messed up bowl which I tend to experiment on. Each of these patterns only took 30 seconds to 1 minute which is the sort of speed I was expecting in the first place.
...I was wearing my sunglasses! I couldn't believe that much flame would leap up. Previous to this, my only experience with pyrography was an el-cheapo hobby-store woodburner used while making Cub Cars with my Dad. This is so cool, or is it hot? I'm having fun, that's for sure!
Thanks again for everyones help, both on and off the forum. Man, I love this community!
I can see that it would. Let it be known, this thing burns FAST. If I ever get to making super thin hollowform (1/16"), I seriously doubt this tool will be any good for decorating it because I would go through that thickness in a hearbeat.
I'm going to try making some tips for fine writing and line drawing. I'm not sure how that will work but I'm sure it will be fun!
This article shows how to bypass the circuit breaker to keep it from cutting the power off while trying to protect the charger from overload. If you are using heavy nichrome wire for a tip it might be a good idea to keep an eye (or rather, nose) on things to be sure high current drain doesn't burn up the transformer.
Watching Graeme make wood disappear in a flash I wondered about using a foot switch. The tip heats up so quick it seems like placing the tip where you want it - then applying current - would give more control. In theory you could go with finer nichrome wire and have the wood keep it from burning up/ Finer wire would also cool off quicker.
Don't forget to wire brush off the tip after each contact with the wood, especially when working with resinous woods.
Wonder if you can metalized the surface of wood enough to be able to use an arc welder?
My gut feeling is the arc, even from a wire welder, would blow away any coating and ignite the wood. You might have more success with a low-temperature solder on a heavily plated surface - think bronzed baby shoes, once all the rage.
The "bronzed" baby shoes were probably electroformed (think electroplating - but a LOT thicker).
I'm surprised that electoforming isn't being used as a "surface treatment". The set up to do electroforming isn't much trickier than converting a battery charger to a wood vaporizer. Seal the piece in lacquer, using a conductive paint, paint on what you want to form onto. A chunk of copper for the anode, a copper sulfate solution in a 5 gallon bucket and you're most of the way their. Dimmer and maybe an ammeter and you're in business. High current, fast build, but lumpy and bumpy and granular. Low current and you get a smoother surface, but much more slowly. Once the copper is on the piece you can do all sorts of things. And if you have some wax between the piece and the conductive paint you'll be electro forming on - you can pop the formed copper off the piece and enamel some or all of it then glue it on the piece.
A couple of us built two of these today using the cheap 6 amp manual battery charger from NAPA. Made a few modifications based on all the helpful hints from Wood Central. First, the 6 amp charger does not have enough room inside for the dimmer switch, I had an old metal 4 gang electrical box that I attached to the back of the charger with nuts and bolts. I wired light switch and dimmer into the metal electrical box. Instead of cutting the charger cables off I just whacked off the alligator clips. Turned a wooden handle and drilled holes based on Molly Winton's instructions. Got wire run through the handle and attached to the Euro-terminals purchased at Radio Shack and then used JB Weld to secure the assembly into the handle. I had already purchased the nichrome wire online from www.jacobs-online.biz - they had free shipping! I set the battery charger to 2 amps, turned on the light switch and dialed in the dimmer - like the ancient cave man I had fire! This thing works great. Made up a couple of different tips and even tried a copper nail that I cut up with my dremel. The unit really vaporizes wood! Total cost of materials was $50.00 for each unit - fun factor out of this world! Have not tried it on the 6 amp setting yet. Will try and get some photos posted.
I made one of those when I was about 13 and used it to plate railroad spikes with copper. (We lived next to the tracks and found lots of spikes.) I used electrical current from a model railroad power supply. The only real problem I had was when I accidentally dropped a railroad spike and broke the glass vessel. The electrolyte made a big spot on the bedroom floor and ruined my mom's card table. She was mad.
The things geeks do for fun instead of knocking over mailboxes - set fire to the house with an experiment gone bad, repeatedly blow the fuses, bring the FCC looking for the rogue transmitter, half kill the little brother with explosive malfunction... I'm just glad my lightning attractor never worked.
