Maple Platter Blanks
Bernie Weishapl
I have a chance to pick up a bunch of maple platter blanks. Most of them are 12" wide X 1 1/2" to 2" thick. Here is the problem. Most of them have some sort of spalting. Is this a issue if using as utility plates? Thanks.
Re: Maple Platter Blanks
Steve Kubien
Steve Kubien
Any fungus or mold which caused the spalting will be long dead by the time you turn, sand and finish them. What's for dinner?
John Veerkamp, Western Mo
I'm sure it's a problem. They may be toxic. For no charge I'll take them off your hands and relieve you of the anxiety of these being used by an unsuspecting consumer. I however am imune to this worry having been innoculated by years of turning spalted wood.
Jorge Casta�eda
Bernie,
As long as they are not punky they will be OK. If still suspicious, I use first sanding sealer and then lacquer. Normally for things that will touch food, all I use is walnut oil, but with spalted wood or any wood too porous, I go the lacquer route, apply several coats and let them dry at least a day between coats and forget it for a while, then a couple weeks later, rub it wit 0000 steel wool.
Bernie Weishapl
Thanks for the replies. I appreciate it. Sounds like I had better get them but will check to make sure the wood is solid. I tried a cheese platter out of some wood that was kind of soft and slightly punky. It did not work well.
