wood movement calculator *LINK*
This should be of interest for those who combine more than one type of wood in their projects. Wood movement becomes an issue. With this calculator you can find woods that have similar specs to reduce the chances of the wood separating later due to uneven wood movememt.
http://www.woodworkerssource.com/movement.php
Re: wood movement calculator *LINK*
good one, and more
That's a pretty good one. (However, I couldn't get it to work with reasonable relative humidity levels, e.g. 70%, even though the instructions said the range was 0-100).
If you like wood-related calculators, WoodWeb has a page with various calculators: lumber shrinkage, board footage, weights, etc., all with the Dr Wengert seal of approval.
http://www.woodweb.com/Resources/RSCalculators.html
One of the most useful things I've found for calculations is a spreadsheet called wood.xls developed at Oregon State University. It's especially nice when comparing species:
http://owic.oregonstate.edu/woodxlsform.php
Re: good one, and more
Thanks John I printed off 2 paper charts that should be quick to use but they have a limited number of species. I'll try out these sites.
