Hey all you smokin' fools. Thought I'd share a new set up Clay put together for extracting smoke from the shop. The other day I was using my "Priddle Flame Maker" woodburner and before I knew it the entire shop was totally filled with smoke. I opened the doors of the shop and smoke was billowing out like it was on fire in there! The old shop wasn't so air tight. The extractor is put together with a bathroom exhaust fan and a pop riveted handy box to the side with a flip on/off switch and then used a flexible aluminum hose that goes through a plywood insert and out the window. It works fantastic and the entire set up cost under $30 and is very quiet. Here's a picture of it along with a picture of the NAPA battery charger that we put together in Graeme Priddle's class last summer. You can see on the side of the burner we installed a dimmer switch with a push on/off switch to adjust the heat. The burning tip was made with PVC tubing, and a little plastic do-dad thing from Radio Shack to secure the copper wires coming out of it and then some metal ones to hold the NiCrome wire for burning. The pens are hooked onto what was the alligator clip wire for charging the battery.
Jen, I applied my disgronificator to your first post without any success. I called Radio Shack and asked about the do dads and the response was, "We're out of stock. A big request came in from corporate to ship all of our do dads to Indianapolis...."
Specifically, you want an 8 position European-style terminal strip (RS # 274-678) that will accept solid copper AWG # 12 wire - about $3.00. Radio Shack sells several kinds - be sure to get the one that accommodates thicker wires. Typically these terminal strips are white nylon insulating strips with tubular metal contacts and set screws that clamp onto the stripped wire ends when they are inserted into the tubes.
Some of these contacts (2) are used with the handle to mount the solid copper wire to the flexible wire, and two "naked" metal sleeves are used to connect the copper wire to the nichrome wire. Very easy to do.
My kids tell me that I have even "more to DO, DAD".
Jen, You have had plenty of time to mess that new shop up.....what's the matter with you?Do you need shavings,I have a few to spare.......let me know.....
