Bowl drying kiln from a fridge
Steve Kubien
Steve Kubien
Hey folks,
I know the basics of building one of these things and have done so. What I do not know is what sort of temps and humidity levels should I be aiming for. Any one got some info or a source of such info?
Thanks!
Steve
Re: Bowl drying kiln from a fridge
Mike Brazeau
Have sent you some stuff I downloaded years ago from rec.crafts. Generally you need to keep the humidity high at the start, which means a pretty full load and then as the wood dries, increase the temperature. There is a chart for equilibrium moisture content at http://www.p1m.com/EQ.pdf
Re: Bowl drying kiln from a fridge *LINK*
Russ Fairfield
Read article in the archive. Link below. This what I do. Only difference is I prefer a dishwasher because it is already vented. A frig is bigger, so you will need to drill some vent holes and use a bigger light bulb.
A dryer for turned wood
Rob Wallace
Rob Wallace
Steve:
Cindy Drozda has an on-line downloadable 2-page pdf file on the drying kiln she has built from a refrigerator. See the link below.
My recommendation is that you be sure that any electrical components you use in the kiln should be weatherproofed as though they were being used outside. With added humidity and occasional condensation, the inside of these kilns can get pretty wet - seal all electrical connections well against moisture infiltration.
Good luck.
Rob Wallace
Cindy Drozda's pdf on Homemade Kiln
Not necessarily a bowl drying kiln...
Old chest freezers work well as do other freezers. My friend Walter has two shielded light fixtures (60 watt incandescent) in his. He drilled two holes in two areas of the lower portion. They can be covered by flaps. He drilled two holes in the upper portion which can be covered by flaps. He has a electronic thermometer probe in a sealed hole to monitor temperature. I don't think he worries about humidity though.
Steve Kubien
Steve Kubien
Thanks everyone. Lots to go on here.
Cheers,
Steve
Matt Overton
Woodturning Design had a good article in their Winter 2010 issue #24. Similar to Cindy's with some good photos
