brown bagging bowls
brown bagging bowls
karl jr
brown bagging bowls
karl jr
It seems that there are two kraft paper weights. Thick and thin. Does it matter which weight paper one uses when bagging bowls?
Re: brown bagging bowls
Bill Howatt
Obviously, they aren't identical but especially in the early stages of drying you should monitor the bowl/bag and change the bag if necessary. If you wrap the bowl in newspaper first then it probably doesn't matter at all but again, you have to monitor the newspaper.
It can be a mistake just to put them away when wet and forget about them for 6 months -mold growth.
Bill
karl jr
karl jr
So, is wrapping in newsprint preferable to kraft paper? Bleached or unbleached; I don't see a functional difference. Maybe I should use about fifteen pages of the daily rag instead of the daily grocery bag?
What are you trying to do with the brown bags. I use them to slow down the drying time of freshly turned green bowls. The idea is to stop air movement which speeds up the drying. I only use them for a few days. It's easy to get mold.
As near as I can tell every one has to figure out what works for them. Our environments are different as far as drying times. Every thing from humidity and air movement to outside temperatures are different in each part of the country. We can suggest techniques that work for us but your techniques may have to change depending on where you live.
karl jr
karl jr
Stick with the thick stuff? I guess my question is whether there is a significant difference between the two thicknesses in their ability to buffer the moisture gradient. I guess the answer is obvious; the thicker paper is a better buffer between the bowl and the ambient humidity.
Bill Howatt
You can if you want to - just regular old newspaper is fine. Like John Lucas says, the idea is to slow down the drying and that's all it does - nothing magic.
What works well in Seattle certainly may not work all that well in the middle of Arizona so you have to get the basic idea and try it, adjust it and try it, .... .
Bill
Karl, John got the answer right, you have to take the basic idea and work it out for yourself. To many variables.
The thickness of the paper may have something to do with it, but so would the density of the paper and the "glue" used to put it together. The wetness of the wood and the species would have a big impact as well as the humidity of the surrounding air, the temperature and air movement would have and effect also. So would the weather. What works ell in winter in VA would not work nearly as well in AZ in the summer, or maybe it would.
Go for it. Try wrapping the outside with more paper than the inside to allow them to dry inward.
