Wtb Powermatic 3520b Bed extension
Joe M
Want to buy a 18" bed extension for a Powermatic 3520b lathe.
Anybody have one they don't use? Please contact me.
Thanks Joe
Re: Wtb Powermatic 3520b Bed extension
Aage Rendalen
Bed extension: I love mine
Aage Rendalen
I use mine as an alternative to a tilt-away system for the tailstock. It's a case of slip off, slip on. Very convenient. Whenever I do hollowing work, I'm happy I have it. I haven't tried for its intended purpose and probably never will. I heard after I bought it that they're no longer making it.
Brad Vietje
Just Installed One... Not Thrilled Yet
Brad Vietje
I just bolted mine on a few days ago, and I must say, I have been underwhelmed. There's quite a bit of slop to the positioning, and no machined indexing pin, key, or notch. It doesn't line up well when the three bolts are all in place, and I have not found the sweet spot where things will line up real well. I will keep fussing with it, but right now, I can't get the tailstock to slide freely on and off the thing -- it either binds up at the junction, or stops with a bang.
Anyone have similar issues?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Just Installed One... Not Thrilled Yet
Brad Put the tailstock on so it's halfway on the bed extension and halfway on the lathe. loosen the bolts and tighten the tailstock. The re tighen the bolts. That should snug it up just right. A actually put mine on the headstock end. this way it sits under the motor when I don't need it. It's out of the way here but when I need it's just a sliding headstocks distance away.
Charlie Anderson
I've never gotten mine perfect. When the tailstock hits the extension it grabs. I used the method John recommends.
I love mine...
Jorge Casta�eda
Brad,
Have to admit I am not trying to make newel posts or similar yet, I bought it to be able to turn beeeg platters 'n bowls and I did installed it in he alternate position, 9" lower I think, it works just fine for this purpose.
The holes and treads were just right.
While not using it is a great place to keep my tool rests and other ancillary stuff.
Brad Vietje
Brad Vietje
Thanks, John.
I never even thought about putting it on the headstock end, which will help solve the other problem of safely walking around the thing! Then when I want to turn large diameter stuff, I can move it to the lower position at the other end.
I have to admit, using the machining on the tailstock or the headstock to align the extension with the ways is simply brilliant! I might never have thought of that...
Clear skies,
Brad Vietje
Newbury, VT
Brad Vietje
Re: I love mine...
Brad Vietje
Thanks Jorge,
Good use for it. For now, I'll try mounting it under the headstock, which will improve a few other things, including the lighting on the work piece, and will be easier to walk around to get into my turning area. When I move into the new shop, I may go for the big swing location.
Great stars tonight ... maybe we'll meet at Stellafane one day soon. Or, if you are driving over to Burlington to visit your daughter, I'm not too far from St. Johnsbury, and our local club meets the 3rd Sunday AM of the month quite nearby, about 1/2 way from here to St-J.
Safe spinning,
Brad Vietje
Newbury, VT
Russ Fairfield
Yup. Same problem, and the fix is what John said about using the tail stock to line it up; BUT you may have to drill out the holes because they don't line up.
Re: I love mine...
Jorge Casta�eda
Hi Brad,
I've been looking up too, maybe I luck out and can attend Stellafane.
If not in one of our trips to Middlebury, where she lives now, we'll pay you a visit.
Thanks for the invite
Jorge
Brad Vietje
Brad Vietje
Thanks, Russ.
I'll give that a go after work this evening. There's a lot of potential adjustment in mine, even with the bolts in place, but I think I may need to grind a tiny bit off the corners where the bed gap doesn't seem to quite match up. I also need to insert a little shim stock around the bottom bolt to lift the end of the extension up a bit -- the bed and face don't seem quite square -- maybe 89 degrees, instead of 90.
At first I was a little disappointed, and figured I would not have this problem if I had a Oneway, but then I did save nearly $3,000 by not buying a Oneway, and $3K can buy quite a little tolerance given my cash flow of late... :\
Safe spinning,
Brad Vietje
Newbury, VT
