No Money No Problem!!!
Lyle Jamieson
With all due respect to Steve I have some big problems with the platform system he is so quick to share with everyone. Every word Steve has said about his home built boring system was absolutely true. But here is the BUT, It is not safe. In my opinion it needs to be captured. We work with an unpredictable material, it grows on trees. There could be a hidden flaw or fault in the wood. Many people use junk, punky, cracked wood that you can not predict if and when it will come apart. If the forces on the cutter are pushing down the handle has to have equal or more forces down to prevent the handle board from coming up and slapping you in the head or worse. Maybe Steve has the strength to hold the handle down but not all turners are young strong hunks. Even a strong MAN would have a hard time holding down on the handle while reaching way out over the platform to undercut a shoulder through a small mouth opening. True the forces with small boring bars and small vessels is minimal. But I didnt hear any disclaimer that said "dont do this at home on bigger(Where do you draw the line??) pieces" People will push the envelop and exceed its limitations. The mass and inertia of big heavy wood spinning around on a stronger lathe will not just stop in a heartbeat when something goes wrong. I would never turn without a top safety bar capturing the handle, any more then I would ride that wooden motorcycle. It would likely drive down the road just fine, but what if I hit a pothole or somebody pulls out in front of me on the bike. There is a simple and necessary fix. Put another strap of wood or any material, pipe, angle iron, 3/4 plywood on edge...anything to stop the handle from violently coming at you. Leave a gap so there is no binding in use. It still fits Steves criteria of cheap and quick to make.
Another safety issue is to grind a flat spot on the boring bar where the holding bolt secures it to the handle. With the bold tightened down on a flat spot the bar can not twist in use. You dont want the torque forces twisting the boring bar in its socket while it is in use inside a vessel. The cutter needs to be securely held parallel to the floor to prevent catches.
I have helped hundreds of students make their own boring systems out of almost any imaginable products, and I applaud Steves ingenuity here. Its a great idea, but lets fine tune it a bit and keep it safe for everyone less experienced then us. Lyle Jamieson
