need suggestion for heavy base inlay
ILYA Z
I just turned a vase whose center of mass is fairly high up. Also, it's got a fairly small base. To make the vase stable, I want to make a heavy inlay in the bottom. This inlay should be (i) round, (ii) between 1.75 and 2.5" in diameter and between 1/4 and 1/2" thick, (iii) heavy and (iv) made of material that can be glued to the wood. I went to a local tile shop looking for round tile of that size. Did not find anything feasible. The closes I got was a hexagonal piece 2" in diameter. Can you recommend something better?
Thanks!
