You can only edit for 20 or maybe 30 minutes after you post.
If you open your own post there will be an Edit and Delete button you can clip at the bottom if they are available. Click on EDIT, enter your password and click on the Submit button at the bottom right. The Password is case sensitive. Your post will be called back up and you can edit it and then click on EDIT at the bottom. I have only done it once or twice so the details are a little fuzzy. If the Edit feature is available you will see it at the bottom and the process is obvious. But if not, there will be nothing to see.
I just Edited this post so I think I got it right.
As Barry mentioned, user edits are one of the perks of registration; you need a profile to be allowed to edit your posts. The default edit time window was 30 minutes, but today I have changed it to 2 hours. That should be enough time for the most thoughtful posters to chew on what they've said.
If you really need to edit something after the edit button goes away, you can e-mail me or one of the other moderators and we can make the changes for you.
