I've started the spindle duplicating
I didn't have much time for turning today. I had lots of other things that had to be done. I made the spindle prototype today and then set up the Vega Duplicator. I made 10 spindles before I had to quit and run errands. I'll make the other 34 tomorrow. The duplicator really speeds this up. This is a simple little spindle and I could have made them without the duplicator but it sure reduces the task to a tolerable level. Using the newer carbide cutter I am able to start sanding with 220 grit. I measured several of them and they are within about .010" of each other. That's closer than your eye can see and I might have caused some of that by sanding on a little different than the next. I'll post a photo tomorrow when I get done.
