A55 Smoothing Plane
Storing Acetone Question?
I use acetone to clean the spouts on my CA glue. I put a little in a jar and drop in the clogged spout. I have spares so I use one of them until it clogs and then swap it for the one in the acetone. Some times I change them often, but other times they sit for a long time. Depends on whats happening in the shop.
The jar for the spouts is one that has the rubber seal under the lid. Not sure But I think the acetone vapor dissolves the rubber over time. The thing that really gets me is that the acetone left in the original container also escapes over time. So, it goes away whether I use it or not. Does anyone have a suggestion how to store a small amount of acetone for a long time? A pint maybe, probably less? And what would make a better container for soaking the spouts? And, Would something less volatile work?
Re: Storing Acetone Question?
adrien
Replace the rubber gasket with a synthetic one, e.g. an o-ring made of butyl rubber?
Don Orr
Barry-I keep my acetone in the original can and don't seem to lose any over time. I've had it for quite a while, but don't use it that often. For cleaning CA tips I kept a plastic soup container from a Chinese restaurant that seals real well. Not even sure what kind of plastic it is but acetone does not disslove it. I have a bunch of them so when one gets gunked up with glue I toss it and start another one. Not sure if any of this any help for you. :\
Baby jars and jelly jars don't work for long term storage. The rubber under the lids does dissolve. I soak the CA glue caps because they always get stuff in them and then won't seal the spout. I soak the spout if it gets clogged also. I don't worry about the evaporation, it's such a small amount and takes a week or more to evaporate. I thought about using film can's but they aren't large enough.
Scott Crumpton
With regard to the acetone in the original container evaporating. If you're buying it in quarts with plastic snap closed caps you should expect this. Acetone has a high vapor pressure and is a somewhat small molecule. The stretching the lid takes the first time you open it will leave enough room for it to get out.
Buy it by the gallon in cans that have a screw on cap with a foil cap liner/seal. Tighten the cap with pliers if necessary and you shouldn't experience much if any evaporation. Store it in a cool location to reduce the vapor pressure. This applies to all solvents to one degree or another.
I buy it in quart cans with a steel lid and then pour just enough to cover the lids into a glass jar.
Greg Jensen
Glass containers are best.
Plastic container can have static plroblems and a sprak can light off the Acetone.
Seal material should be Viton. You can also get a lid that has a polyethylene or polypropolyene seal. Teflon is also OK. A cheap solution is to cut a disk out of a empty milk carton and use it for a seal.
Thanks Greg. I had not thoguth of a spark. Sort of a Duh moment.
The problem is really with the stuff left in the factory container. I see the stuff in the jar as getting used, so if it goes away I just figure it got used up. What bothers me is to go back to the factory container and find that it just went away.
Galen Vetterick
I buy acetone in the quart metal containers with a snap seal plastic top. I use it faster than I have ever seen it evaporate. The snap cap seals tight enough that I can invert the can and it does not leak.
For soaking small parts I use my endless supply of prescription pill bottles that have a twist top with a plastic compression seal. Can invert those and they do not leak nor do they desolve any part of the bottle.
Don't store upside down just tested to see if they seal well!
Galen
