CA Glue Color
CA Glue Color
CA Glue Color
Terry Fox
Someone has to follow one of Tery's masterpieces to bring us back to earth - at least to my level.
Why does clear CA glue dry dark? On a light wood, like ash, I fill a crack with ash sawdust and clear CA and it looks like a bark inclusion when it dries. Is it something I'm doing, or a law of nature? I've seen brown CA glue for sale - why bother when the clear dries brown anyway?
Can someone shine a light on this murky issue?
Thanks, Terry.
Re: CA Glue Color
Re: CA Glue Color
Lan Brady
Terry,
I have found that CA glue dries clear. It is the filler(sawdust) that darkens when used. If you are tring to hide the crack you can add a little whiteing (basically chalk dust) to the mix. But you will not be able to hide it completely. I mostly use charcoal dust to make it really contrasting dark. Looks a lot more natural than an attempted repair.
Just my ramblings, Lan
Re: CA Glue Color
Re: CA Glue Color
Skip Beardsley
Terry,
I find that if I seal the area around the crack, or the entire bowl, and then apply the dust and ca glue if makes a cleaner, neater fix. Most of the time I use either charcoal or expresso coffee grounds. Either of those seem to make a nicer fix.
Skip
Re: CA Glue Color
Never Dark
Barbara Gill
My CA only dries clear unless there is something mixed with it. I have never heard of regular CA drying any color other than clear (I know clear is not a color). Some brands will occasionally cloud up with the use of accelerator.
Re: CA Glue Color
Re: CA Glue Color
adrien
You're comparing side grain to end grain: the sawdust is a sort of super endgrain and that's the darker shade. You're looking at a lot more empty space the glue fills than it does on side grain.
Re: CA Glue Color
Re: CA Glue Color
Allen Neighbors
I've had CA that ran down the side of a Bois d'Arc bowl (when I sealed a crack with just CA) and it left a dark streak that wouldn't even sand out. So here's what I do now to solve that problem:
I modified Carole Valentine's 50/50 Lacquer Wash to 65% Thinner/35% Lacquer, and seal the bowl with it before I use CA. After the lacquer wash dries about 2 minutes, I use the CA, and then sand the bowl normally. Even after the lacquer wash... when sanded, the bowl will take a good Danish Oil finish. But I've never had the CA to stain the wood after a lacquer wash. It seals just enough to keep the CA from staining surrounding wood.
Re: CA Glue Color
Dick Hines
Re: CA Glue Color
Dick Hines
CA will stain the wood and no amount of sanding will get it out.
When I fill small cracks or places I can not seem to sand out I will use med. CA and then power sand over the spot. The dust from the disk will fill the crack. The med. CA does not seem to stain like the thin.
Re: CA Glue Color
Re: CA Glue Color
Dick, You do wait for the CA to cure don't you? You're not sanding wet CA are you?
I have also noticed that the medium CA does not wet and stain or darken the surrounding are nearly as badly as the thin. I have a piece of furniture that includes some burl panels and the CA repairs show in them. No one but me notices, but they look like crap to me. They look like wet splotches. If I had realized how much they would have bothered me, I would have coated the entire piece of burl with CA, at least it would have been consistent.
Re: CA Glue Color
Re: CA Glue Color
Bill Howatt
I always try to do my CA repairs well before the last cuts on the workpiece which gets the "spill" off. Of course, the nature of the wood depends on how far the CA penetrates and also why the thicker CA has less of a problem.
Bill
Re: CA Glue Color
Dick Hines
Re: CA Glue Color
Dick Hines
Yes Barry I do sand with the Med CA wet. With the lathe tuning very slow but before the CA dries. The sand paper froces the dust into the crack on top of the CA and fills it. If it is not compleatly dry I will hit it with activator
