So many ways to answer this
Steven Antonucci
A good mini is certainly an option. And you can make or buy an extension if you need to go longer for spindles. A buddy of mine made one for turning baseball bats. Works well enough in that type of work.
If I wasn't sure what my true intentions with turning were, I would probably do something like this or pick up a used lathe that was bigger. Either way, you probably end up about the same $$$ and having to make stuff for it to work in the varied items you describe. $300-400 invested, likely returns $300-400 if you decide this isn't what you want to do. If you buy junk, you are usually stuck with it or 50 % of your cost.
I would also encourage you to buy 3-4 tools and work at them. Most turners have way too many tools (my hand is up). Until you can use them, it doesn't make sense to buy more. Having a chuck solve a lot of hard problems quickly. There are some inexpensive chucks on the market, and they work well enough for what you describe. $200 should get you started.
If you've never turned, find a local AAW chapter and join it. Might cost you $25, but it's a great investment.
S
