Guess what I learned today?
Barb Siddiqui
Barb Siddiqui
When this happened, it made me laugh, because at the instant of destruction I knew what I had done. 'The light bulb' went off at the same time it broke out.
What I learned was, one does not undercut the rim and then work concentrating on a perfectly smooth interior finish all up the inside of the bowl. Ah yes. Life as a beginning turner can be ...insert word here....
Next time, finishing the inside comes first, and undercutting the rim afterward. sigh.
Re: Guess what I learned today?
Jorge Casta�eda
Hi Barb,
It happens to all of us, today I made the wide part of a funnel, just went right through the bottom of a bowl.
I finish the outside completely before going into the inside when working bowls, in other things like goblets or boxes, yes, finish the inside first.
Keep at it, you have to make a dent in that wood pile... :D
Jorge
That's exactly what I blew up the other day. It was not the under cutting or the turning the inside. I simply got carried away and didn't measure. When I started sanding heard a funny noise. I stopped the lathe and didn't see anything so I started it up and heard the noise again. Stopped the lathe and could see some light through a small crack. I pushed on it and my hand went right through. I had turned about a 1/2" down to a thickness of 1mm or less.
Turning a lip isn't that bad and you can hollow them first and then the rest of the bowl. The trick is how you turn the undercut and how you start the cut. I typically use a gouge with a flat grind. Before I started doing that I used to use my bowl gouge on it's side. I turn the flute toward the bowl and cut with the lower lip. This is a shear scrape and I cut from inside the bowl toward the lip.
Barb Siddiqui
So, doing dumb things
Barb Siddiqui
never really goes away? hm. I think I was just so heavily concentrating on a smooth scraping cut with a fingernail gouge turned on its side, that I plumb forgot the undercut rim would be a grabbing point for the tool. I was bringing it up from the bottom very finely and gently. Better off to use the flat bowl gouge from outside to inside, the other way, with a fine cut, I guess. And it was working so well.
Barb Siddiqui
Barb Siddiqui
I'll keep at it, Jorge. I have lots and lots of green maple to play with! We have all the spring birds out now, and they are dazed and confused standing on the stumps of our poor old tree. I think they feel they have the wrong address.
Re: So, doing dumb things
Barb It shouldn't be a grabbing point if you follow the curve with the same pressure. What can happen anytime you work in the rim area is the wood can flex especially if it's green and thin. That's why I usually thin from the rim down and never go back. I'll cut the first inch to the proper thickness and work on it, cutting, scraping, whatever. From there on I work toward the bottom of the vessel and don't go back to the rim.
Bob Macgregor
I imagine you have heard this saying: "Nothing is fool-proof to a sufficiently talented fool"? Present company excepted, of course!
BOB
Barb Siddiqui
Aha
Barb Siddiqui
That is very useful info. Back to my wood stash. Thanks John.
Barb Siddiqui
Barb Siddiqui
I hadn't, but it would apply here if edited to 'insufficiently talented!'
Ric Taylor
You Had it Right the First Time
Ric Taylor
Barb,
You were correct, always finish the rim first, then work your way down the sides toward the bottom. Never go back to the rim.
If you go back to the rim, there are two problems. First, the thin sides are not strong enough to support the forces generated while working on the rim. Second, if you do go back to the rim, it may have warped while you worked on the sides, increasing the chances for a catch when you go back to the rim, which is no longer round.
Ric
Barb Siddiqui
Thanks Ric.
Barb Siddiqui
