Here is a photo of all the parts completed so far. I still have to flatten the top and drill the holes for the spindles. The two rings are made by stacking 2 8 segment rings with the joints overlapping. The lower rails are in a slotted dovetail and the upper rails are dovetailed in from the top. The lower table will cover the slots for the sliding dovetail rails.
Now all I have to do is turn 44 short spindles exactly alike.
Anyone have any suggestions for glueing 24 spindles inbetween the top and the rail. My thoughts are to put glue in the table top turned upside down. Put the spindles in and install the rail to keep everything aligned. After that's dry I turn it over, put glue in the rail holes and put the top with spindles in and clamp it. This 2 step procedure should keep glue run out to a minumum.
I think you are on to the right assembly method. I wouldn't try to get all 24 spindle in at one point. Perhaps 8 evenly space 3X until they were all glued. the issue is not one of can you do it, but rather, can you clean up 24 spindles worth of squeeze out at one point in time. 8 with the open spaces will be much more manageable.
Not much choice on the other side though :-)
S
P.S Did I miss the original thread? I'm not sure I understand what the table will look like?
Bout 30 years ago I assembled some multi-spindle/ring things in the wood shop at Berea college. All I remember is one end was glued and set before the other, and it was a big pain to get everything lined up! Seems it might be easier if the spindles tenons were graduated lengths, but that would be trickier to make.
Do all the spindles need to be glued? If the spindles are mostly for show then you could glue in all the spindles to the first piece but only glue in 3 or four in the second piece. All the other spindles will be contained by the glued in spindles. Use hide glue so you have an escape if things go wrong (or there is a repair in a few years). You could insert a couple of drops of glue into the lose spindles after it is put together.
Tape the ends of the spindles and apply finish be for glueing. Glue can be cleaned off a finished surface quickly and completely.
you might want to use a "lazy susan". Attach the lazy susan to your assembly table and clamp the piece to receive the spindles to the lazy susan. Having a clear view of the spindle insertion makes life better. Working from one comfortable, well illuminated position with all supplies at hand will make the frustrating process of spindles popping out easier to deal with.
Round over the unglued ends of the spindles to simplify the spindle insertion process.
Dry fit all the spindles in the holes. Mark the spindles if there are some that need to go into specific holes. The end of the spindle should fit and bottom out in the hole. If the spindle end is a little to large so that it doesn't bottom out in the hole that spindle will stick up to far for the next glueing. So dry fit and mark each spindle with blue tape and a number.
It is surprising how holes drilled with the same drill bit can be different sizes. The ends of the spindles will need extra attention after the dry fitting.
THanks Richard. I've glued a lot of spindles over the years so I'm well aware of the problems with size and insertion. It's good to be reminded though. I will definitely go through a walk through before any glue is applied.
