Alternate Micro Sander
Tommy Holmes from NW FL
There's been some recent threads about the Pfingst micro sander. I had been looking at them for a year and the threads brought on the fever to have one that I couldn't resist and bought one. It works nicely for detail sanding.
While looking at it it made me think of an electric eraser and checked a few websites and found that they are available in the corded type or battery operated. I picked up a corded, used Alvin brand off ebay for about $8 and although it only operates at 4600 RPM it seems to work just as well as the Pfingst micro sander. I used the 1/4" head from the Pfingst. It fit perfectly in the collet collar and has a spring loaded button on the side of the neck to turn it on and off. It also works with a variable speed foot control. Some electrical specs, that I don't know much about, are120v, 50w and .5 amps.
Some that I looked at run at 4600 rpm and some run at 12000 rpm. Under the descriptions of the battery operated ones they give the maximum RPM with a full charge so it sounds like they will slow down as they lose a charge. The battery operated ones are fairly small while the corded ones have a small neck but a pretty large head where the motor is.
May be a cheaper alternative or fill in till $79 to $90 comes around.
Re: Alternate Micro Sander
Mike Jones in Redding, Ca
That's a good tip. Thanks!
Dinyar Chavda
Tommy:
What was the model number of the Alvin that you got? It seems that the corded ones have been discontinued, and so the only place to get them would be on eBay---and I did not find any corded ones listed under recently completed sales there either. Having the model number would make it easier to find one that I know works.
Ha, what a great idea! Larger then the little thing but designed for comfort and I've had several languishing in a box for at least 10 years!
Tommy Holmes in NW FL
Dinyar
I have the Alvin EE175. I think it was probably one of the cheaper ones. I think the Bruning is a better brand. From what I've read most any of them will work. Hope this helps.
Tommy
Dinyar Chavda
Thanks. I'll look it up.
