Tripoli inclusions
Tripoli inclusions
Tripoli inclusions
Dan Oliphant
Help wanted!
What would be the best method to remove tripoli compound that has become inbedded in larger pores of an end grain Ash hollow form? The finish is lacquer, and I would rather not damage the finish.
To see the tripoli, look closely at the lower portion of the piece.
Thanks for any inputs.
Re: Tripoli inclusions
Rob Wallace
Rob Wallace
Dan:
Is this tripoli or white diamond compound?? I have never had problems with tripoli, but have had several similar experiences with white diamond (...it looks really bad on walnut!). Seems a bit too white to be tripoli...
I suggest using a piece of terry-cloth towel soaked in mineral spirits to moisten the surface and to work-out the particles in the pores. A tooth brush soaked in mineral spirits might work too. I have also had some success blowing out the material once it has been wetted with mineral spirits. The mineral spirits should not effect the dried/cured lacquer finish; just DON'T use lacquer thinner!
Good luck,
Rob Wallace
I agree with Rob. Mineral spirits will dissolve the wax then it's up to you to figure out how to get the stuff out of the pores. Tooth brush, paper towels or any kind of absorbent cloth.
TomCollins
Dan,
I have no experience with your particular problem but would you be able to use compressed air blown into the hollow form to force the Tripoli out after you have softened it with the mineral spirits? I have done this with oak to clean out the pores. If you try this set the pressure down low to start.
TomC
I've had some success scrubbing with a very fine bristle brush, especially on long pores. I admit to resorting to coloring some stubborn dots of contrasting compound then covering with new finish. A white dot under the finish of a dark wood is horrible. Once I even started over with coarse sandpaper.
But mostly, all this has taught me a lesson - fill the pores first, even before fine sanding. I generally do this with as many coats of sanding sealer as necessary - I like the Mylands shellac-based sealer. On walnut I like to force dark grain filler into the pores first - I like the way that looks. Rarely turn ash.
Don Pencil
Don Pencil
Dan,
I believe the suggestions here are good.
I am curious if the compound is under the lacquer or over it?
Secondly, why the use of white diamond or tripoli with lacquer either over or under it?
Don
Dan Oliphant
Thanks for the information, it was indeed helpful. I was able to remove all visible white diamond compound (as in face to face conversation sometimes the mouth and the brain arn't on the same page). I used a combination of mineral spirits, a cotton cloth and a soft tooth brush to dislodge most of the white diamond compound, this was followed up with compressed air several times.
To Don's question whether the compound was under or over the lacquer, it was over, prior to wax. The reason for use was to finish smoothing the lacquer prior to wax. Why would I not use white diamond?
White Diamond in inclusions
Allen Neighbors
I usually sand Ash, and other woods of similar styles of grain (even walnut) until I've finished with 400 grit. Then I apply the lacquer (pre-catalyzed, nitrocellulose) and sand lightly between coats with 400 grit, and keep applying coats of lacquer until the pores are filled. Then I use wool-wax, with 0000 steel wool, then finish with the final coat of lacquer.
Then, if for some reason it needs buffing, the white diamond will not remain in the pores.
Not necessarily the way to do it, but it's the way I do it most of the time.
Re: White Diamond in inclusions *BIG SECRET*
steve worcester
I buff with auto compounds and you can easily remove the extra tripoli, white diamond, whatever with a crest spin brush. Works awesome. Use it with a spritz of water before the wax (since wax and water don't like each other) or after with lacquers and film finishes. Works with getting the crud out of inclusions and stuff real well.
