I am not an instructor.... of woodturning at least
However, a young man of my acquaintance wants to learn how to turn.
I asked him what he want to learn to turn - "Everything" was the reply.
So - what would be some reasonable projects for the beginner?
I was figuring on a simple bowl and a simple box. Possibly a rolling pin - but not a honey dipper. I'm looking for some reasonable spindle project ideas.
Any thoughts??
TIA
Re: I am not an instructor.... of woodturning at least
Mike Stafford
Jerome, a simple bowl is a good beginner project but if you really want to keep this young man interested offer up projects that are gift oriented and useful, i.e. bottle stoppers, pens, weed pots, candlesticks etc.
All of these projects build skills and can be done fairly quickly. Some people are turned off by turning a bowl when they find out how much wood has to be removed and how much sanding they might have to do. I always start a beginner with a small bowl in the 4-6 inch range.
Pens are universally fun for beginners but of course you have to have the mandrels and hardware for the pens.
karl jr
Napkin rings are the first thing I made. Lots of things built into that project, finding the centers of the blank; roughing to a cylinder; beads and coves; drilling and parting-off. Intro to the skew, too!
Russ Fairfield
My suggestion is to NOT put the emphasis on the project until they have learned how to use the tools and make shavings. Starting immediately with a project puts the emphasis on making something and saving the wood rather than the tools.
karl jr
Yep, you are right. The napkin rings came well after an intro to the parts of the lathe, safe operation of said lathe, safely mounting wood, turning tools and the all important bevel, etc. Then I got to learn about catches! After all that, I made some napkin rings.
Turn a stool, 4 legs and and top and right up your alley. You can use the same joinery as your chairs. The legs can be very simple in design and if you keep them thick and short they will be easy to turn.
Even though I wholeheartedly agree with Russ on NOT FOCUSING on making something, it's almost impossible to do, much like that pink elephant now dancing in your head...
How many tools in the shop require "practice" before you can make something? Not that many jump to mind first pass...if it were me, I'd start with the simplest of projects, like a rolling pin or a pointed stick and focus on getting the basics across.
Steve
Re: I am not an instructor.... of woodturning at l *LINK*
Fred Holder
When I start with a rank beginner, I introduce them to spindle turning, between centers. I first have them rough the piece to round and as smooth as possible with a roughing gouge and then smooth it as much as they can with a skew chisel. Then teach them to make "V" grooves with the skew. I then teach them to make beads between two "V" grooves, first with the skew and then with the spindle gouge. At that point they have began to get used to using the tools to cut wood. I then teach them to make coves with the spindle gouge.
This generally takes two to four hours until they get to the point where their tool control is much better. At that point, I introduce them to turning spinner tops, which teaches them how to make cuts across endgrain and to turn thin spindles. When I first started turning 20 plus years ago, I would often have to be out of the shop for several days to several weeks. I found that turning a couple of spinner tops was a good way to regain my control of the tools.
The next project is then a pen using a BIC pen insert. This is more spindle turning, learning to drill a blank freehand, and making some "V" cuts, plus parting off and finishing the end by hand.
After they have gone through these types of challenges, I may introduce them to bowl turning using a 3" or 4" bowl that doesn't take to long to complete. This also gives them a bit of practice on sanding and finishing of a piece.
The next project is generally a box, which gives them experience in hollowing end grain and fitting a lid to the tenon on the bottom portion.
Up to this point, I sharpen the tools for them. Now, I teach them how to sharpen their tools and introduce them to various recommended jigs and also how to do it freehand.
After that, it is pretty much what they would like to turn with tips on how to turn difficult parts of the project that they choose.
If you are a member of AAW, there is a resource that should be of interest to you: a comprehensive guide for teaching beginning woodturning- everything you need to organize a strategy for a new turner�s successful entry into the craft. It is FREE to download at:
Bob Macgregor
Fred's suggestion of a top is good; if your student has kids, maybe a magic wand, too?
You might also consider a garden dibble, which is a good beginner practice project for skew and/or gouge. You can even show wire burning the inch marker lines on the dibble; it's always fun to make some smoke!
BOB
Scott in Falcon
If he happens to be a Scout (Boy Scout or Cub Scout) a smaller version of a napkin ring makes for a great neckerchief slide. It's the first thing I have boys turn for their Woodworking merit badge.
