What's happened to the edit option?
JamieDonaldson
JamieDonaldson
test message
test
Edit is still alive and well, at least here. I posted this message with just the word 'test' then edited it. Remember you only have so many minutes after posting to edit, although you can delete at any time. Also, be sure there is a password in the field at the bottom when posting - I haven't tried it without but the instructions indicate it is needed to have the option to edit or delete later.
From reading other messages here, if you still can't edit it may be a problem with your profile. (I have no inside information on any of this.)
When in doubt....
... check the FAQ file. Here's what it says about editing:
5. Edit or delete your message(s). Registered users may edit their posts within 30 minutes of posting and delete their post anytime. Just open the message you wish to modify or delete, check "Edit" or "Delete" at the bottom of the message, and type your password.
I could increase that 30-minute default if enough people would prefer a longer editing time window. And, if you ever really want to edit something after the opportunity goes away, send me an e-mail. I can always input your changes through the administrative interface.
