Bottle Stopper ROund Top
Jerry Lear
I am new at turner and have been trying bottle stoppers to gain practice. I am having trouble in rounding the top in the bottle stopper without getting a "catch". I am keeping the tool rest parallel to the stopper but when I begin to make the turn at the top is when I run into trouble. I am using a spindle gauge for this operation. What am I doing wrong? Thanks in advance for your help.
Hi Jerry, you have to roll the tool, so you will end up with the flute facing ninety degrees from the turning, with the bevel rubbing. You will have a hard time if you attempt to keep the tool on one plane..the trailing edge will catch, as you are experiencing. Start with the bevel rubbing, flute facing upward, then roll the tool as you progress. Keeping the cutting edge on center helps.
