OT: tried some knife handles
ebd
The tanto blade (upper) is macasser ebony and the skinner (lower) is cocobola.
ebd
Re: OT: tried some knife handles
Nice handles, did you make the knives as well?
ebd
I wish - I ordered blanks from
http://www.premiumknifesupply.com/StoreFront.bok
They come very sharp and ready to be handled. All you have to do is pick the wood and apply it. Their pin size "estimates" are somewhat off so if you order, wait till you get the blanks and determine the size of brass rod you need. I tried drilling the blanks with "hard metal" colbalt drills - NO WAY. I'm not sure that carbide metal working tools would work on these hardened blanks.
I'm not estatic with the results but this is my first attempt. The final knives are certianly serviceable if not perfect and the beauty of the wood distracts the eye from the errors. I'm ordering a few more blanks to attempt to make some as close to finely finished knives as I can manage. I believe that the critical piece is to take enough time, rather than hurrying to see the finished product.
Jennifer Indy.USA
These look really nice. I've always thought it might be fun to try to make a knife.
Jen
I am definitely going to get into knife making some day. I've been interested in it for many years. I'm always buying knives trying to find one that's perfect for me. One of these days I'll just learn to build it. I've made a couple of small ones using the grind away metal technique but I really want to learn to forge them from scratch.
RPE
I tried knifemaking this weekend also. I got a knife blade set at WoodCraft'. It was $20. That was for the blade and the pins. I made the handles out of some Bloodwood I have from Peru. The pins thata came with the blade are way to short so I had to make my own. I went to Lowes and bought some #8 Copper ground wire. I chucked it in the drill press and straightened it and filed it a little to fit. I cut it to length with a hacksaw blade. It is very hard to judge the length of the pins and to cut them to length and expect them to be flush. I didn't fair very well. I split one handle putting one of the pins in. It was barely visible but it split just the same. I made another set of scales (handles) using a flush cutting bit in my router table. They turned out great.
ebd
I got brass rod from the local hardware store. Took the blades with me to make sure I got the right size. Once the handles were shaped and drilled, but before final sanding, I cut pins that would extend a tiny bit out from the handle Measure with a dial caliper. I drilled the holes for the pins same size as the pin diameter. That way they were snug but not tight. I could put the handle on to see the fit then take it off so I didn't bugger up the steel while shaping & sanding. After final sanding I peened both sides of the pins to flatten and widen the exposed surface. Seemed to work really well and didn't need glue. I know some guys use epoxy but this way if the handle gets buggered up I can punch the pins and pop it off and make a new one.
